Shifter Linkage
Old Nov 9, 2011 | 03:17 PM
BackRoader's Avatar
BackRoader
Go with the heim joint. e-bayed a linkage and bought chrome plated heim joints seperately and saved lots of money.
Old Nov 9, 2011 | 03:21 PM
Mick's Avatar
Mick
If you want to keep it simple and inexpensive , pick up a couple of these.
http://www.midwestcontrol.com/part.php?id=301
I do this on each bike first thing and get rid of a problem before it starts.
I also drill and tap the primary at the front shift shaft for a 1/4x28 grease fitting.
You can see it in the picture at a 45 degree angle.
This combination makes the shifter feel more positive and neutral easier to find too.
Over the long haul . the shifter shaft gets loose and dry and will affect shifter feel eventually.
This combination works great and looks OK I suppose , not real fancy.
I keep a pair of stock joints in my tourpack for stranded travelers as a pay it forward kind of thing.
Mick
Old Nov 9, 2011 | 03:41 PM
ybnorml's Avatar
ybnorml
Add a little bling-bling to the left side.....
Old Nov 9, 2011 | 03:48 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Originally Posted by Arizona
The factory linkage is a "weak link". Either carry a spare with you or go with the upgraded linkage...
Ditto...I changed mine out the first day I bought the bike and put the spare in the bag.
Ended up giving the spare to a guy stuck in a parking lot with a broken shifter.
Old Nov 9, 2011 | 03:57 PM
one-up's Avatar
one-up
I installed this one. Seems tighter and has more of a positive feel when shifting. Can find neutral easier too.
Custom Gear Shift Linkage - Harley-DavidsonŽ Scripted
Kick your custom into gear with this collection of high quality Custom Shift Linkages. Available in a variety of designs to match your bike's style, these linkages feature aircraft-quality rod ends for easy adjustment and smooth operation. The easy-to-install linkage kit includes a transmission lever cover and decorative acorn nuts and bolts for a complete custom look. Easy-to-install.
33801-09
Fits '86-later SoftailŽ and Touring models. (Does not fit '97-'99 FLSTS models or models equipped with SoftailŽ Extended Reach Forward Controls.)
MSRP US $129.95
Download Instruction Sheet
Old Dec 5, 2011 | 09:11 PM
rdam's Avatar
rdam
Originally Posted by frenchbiker
The shifter linkage isn't the issue, the issue is what's at both ends. Replace the 2 crappy ball joints by 2 heim joints and you won't be stuck in the middle of nowhere unable to shift. My front ball joint broke at 9,500 miles on a Sunday (dealerships closed). Luckily I had 2 plastic ties in my toolkit. I could ride back home.
My "crappy ball joint" (front) finally broke after 6 1/2 years and 41K miles. My fault. I knew it was a weak link and always intended to replace it. Two or three zip ties will get you home in a pinch and I was only about 10 miles from the house.
I replaced it with a chromed rod with Heim joints and nice chrome hardware. It feels substantially better.
Just a reminder. They will fail. It's a crappy design and should come from the factory with Heim joints. Pack some zip ties if you have'nt replaced it yet.
Old Dec 6, 2011 | 12:14 AM
X Iron Butt's Avatar
X Iron Butt
I definatley noticed an easier nuetral and overall more positive shifts up and down. Got mine on e bay for less than 1/3 new. Just wait for it. Guy sold bike and took off to sell later.
Old Dec 6, 2011 | 01:12 AM
Mike's Avatar
Mike
You just need a couple of 5/16-24 RH female heim joints, a couple of nylon washers and a couple of button head bolts to upgrade your shift linkage. Total cost is under 10 bucks at the hardware store.
Old Dec 6, 2011 | 06:50 AM
lionsm13's Avatar
lionsm13
Mick
Great idea!!
Old Dec 6, 2011 | 09:07 AM
Geoff's Avatar
Geoff
A shift linkage with Heim joints has a firmer feel (less slop) and is stronger than the factory linkage. It looks better, too.
