Only 3qts came out
Old Nov 12, 2011 | 08:25 PM
TORQUEY's Avatar
TORQUEY
Here's your answer:
http://roguechopper.com/products/twi..._Kit_RC120.htm
Old Nov 12, 2011 | 08:41 PM
TUCCI's Avatar
TUCCI
Originally Posted by Indianspringsaz
I just bought a Scavenger oil thing that will flush that last quart out while replacing it with fresh.
Just google Harley oil scavenger.
Great product, nothing like getting all that old oil out.
Old Nov 12, 2011 | 09:30 PM
Eric Moore's Avatar
Eric Moore
if you have a oil cooler... you can just remove the oil return line from the oil cooler & add a small tube & do the same thing..I do this on my big dog as I have coolers on them........ just leave your old oil filter on untill the oil pumps clean.. then reconnect the oil lines & change the oil filter.........
Old Nov 12, 2011 | 09:47 PM
kpb46's Avatar
kpb46
Originally Posted by rn0229
. On my 07 flhp with same(?) engine I drain 4 and put 4 back in. Why is this?
My 07 Ultra has almost 60,000 miles on it. Change oil every 3000 mi . I could NEVER get 4 qts back in. It would be running all over the floor. 3.5 MAYBE
PS My buddies 07 Street Glide is the same way
Old Nov 13, 2011 | 12:22 AM
BLKBAGGER's Avatar
BLKBAGGER
I have never measured how much oil I drain out. I do only dump in 3 qts and run the bike and then add from there if needed.
Old Nov 13, 2011 | 03:42 PM
TUCCI's Avatar
TUCCI
Eric, you referring to the above while your running the Scavenger system or is this what you do to eject remaining oil left in your engine?
Old Nov 13, 2011 | 04:07 PM
rn0229's Avatar
rn0229
Talking 3 qts?
Sorry it took so long to get back. The bike was HOT when I drained the oil. The reason I knew how much oil came out was because I poured the waste oil into a clear plastic jug. The scavenger willnot work on an A motor.
Old Nov 13, 2011 | 04:12 PM
Eric Moore's Avatar
Eric Moore
no I dont have the scavenge system... it does the same thing... it just pumps out the oil stop when you see clean oil running out your tube from the oil cooler...
Old Nov 13, 2011 | 04:35 PM
TUCCI's Avatar
TUCCI
So how do you keep all the oil from running completely out then? Or are you filling the oil tank as its running the old oil out?
Old Nov 13, 2011 | 04:45 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
It's getting a little old, shake it next time..
