Lost rear brake coming down mountain
Old Nov 15, 2011 | 01:42 AM
  #31
emwolb's Avatar
emwolb
the people who designed the brake system were probably pretty good with brakes. they specify dot 4 or dot 5 for a reason and it's covered in your owners manual as well as labelled on the top of each master cylinder cover. i really prefer the older stuff that doesn't eat paint, but i also really prefer much more, growing to a ripe old age. obey the reservoir cap and use what is specified. i'm glad you got it figured out and swapped back to the right stuff after flushing. ride safe.
Old Nov 15, 2011 | 01:56 AM
  #32
Sol's Avatar
Sol
30 posts into this thread and none of the Keyboard Kowboys paid attention to the OP's description of brake fade on a mountain road.
Basic physics that most of us flatlanders ignore: high elevation = lower atmospheric pressure = lower boiling point for liquids, including brake fluid.
Minor issues with braking systems or braking techniques that aren't noticed at sea level can cause fade (boiling of the fluid) at elevation with even mildly heated brakes. Best practice is to take it easy and gear down on mountain roads to avoid brake fade.
Old Nov 15, 2011 | 05:09 AM
  #33
cromagnon's Avatar
cromagnon
Originally Posted by highmarket
Ya, I`ve followed people like you that ride the brake, time to take a riding class?? ya think?????
Read all the posts smart ***. You have to use your rear brake once in awhile coming down a mountain. The fluid was low.
Guys like you, got nothing to add except asshat replies.
Old Nov 15, 2011 | 05:47 PM
  #34
sgdiesel's Avatar
sgdiesel
That is a really bold statement you open with so I presume you checked your facts first before making it!
I took the liberty of checking first and can confirm as follows:
Highest point on BRP is just over 6000 ft. Whilst I could not find the specific altitude vs boiling temp relationship for brake fluid it was, naturally, readily available for water. The boiling point drops from 100 degrees (Celsius) to 93.5 - so I am going to have to beg to differ with you on this.
I have also ridden through much higher altitudes on the Rockies and was blessed enough to drive the Grossglockner pass in Austria. On both occasions I did not see any signs warning motorists that they were about to plunge to their deaths due to premature boiling of their brake fluid!
Old Nov 15, 2011 | 08:09 PM
  #35
toxic donkey's Avatar
toxic donkey
Good day gents, thought I'd chime in. I still have a race bike and try to do 1 or 2 trackdays a month, money permitting. Most of my days are in the summer months at little talladega, road atlnta, barber and nashville. Obviously all are in the south and I dont have to tell you how hot it is on the pavement somedays. With that being said I have never boiled the brake fluid(dot 4) and of course if Im not on the gas im on the brakes. Yes, I have experienced some fade at times when doing long sessions with old fluid and mostly prior to running steel braided lines. I know this is apples and oranges comparing sport bike to harley, but at the end of the day the brake systems operate the same. In my expereince my problems with the brakes have been mechanical in nature or low fluid level. Just my 2cents.
Old Nov 15, 2011 | 08:38 PM
  #36
cromagnon's Avatar
cromagnon
A lot of techno mumbo jumbo on this thread so far.
Bottom line: the fluid was low. It did not boil or foam. When I flushed it out existing fluid was nice and clean.
Looks like, when I did the pads and bled the brake, I should have pumped it one more time to add more fluid.
So 2 lessons learned: Make sure reservoir is filled and don't use DOT 5.
One more thing ... The touring series bikes have outstanding front brakes. I was never in any danger coming down that mountain road. Front brake and gearing brought the machine to a stop nicely.
Old Nov 16, 2011 | 07:57 PM
  #37
highmarket's Avatar
highmarket
Ya I know I`m a smart A$$ can`t help it, no harm intented I`ve followed guy like you that check there brake fluid after they have no brakes also, bottom line,,, at the bottom of the hill, they have no brakes
Old Nov 16, 2011 | 08:11 PM
  #38
Deuuuce's Avatar
Deuuuce
Using the rear brakes too much (and fluid too low).
All that weight going downhill, why even bother using the rears?
Old Nov 16, 2011 | 09:57 PM
  #39
Denver Dave's Avatar
Denver Dave
For the altitude statement/question, I have lived for many years an hour or so away from both Loveland Pass and Independence Pass here in Colorado. Both passes are approximately 12,000 feet. I've ridden and driven over both numerous times every year. I've never heard of nor experienced any brake fade due to the change in atmospheric pressure. Interestingly, I have found my muffler bearings seem to wear out much sooner when riding at high altitudes.
Old Nov 17, 2011 | 01:53 AM
  #40
sgdiesel's Avatar
sgdiesel
+1
I have to say I am somewhat confused by this whole thread. Maybe it is a case of 2 countries separated by a common language, but my understanding of "mumbo jumbo" is a polite term for BS.
As I stated above, I see a case of listening to what you want to hear! Why not do independent research - it takes 5 minutes on Google and the information is overwhelmingly clear and evident
The OP has a potentially serious and dangerous situation on his hands that can only be correctly rectified by doing a thorough inspection and service.
That is not going to happen, so I have moved on
