Cleaning Wheels
Old Nov 16, 2011 | 08:30 PM
noserider's Avatar
noserider
Originally Posted by fabrik8r
Sounds like pretty good advice, only thing I would change is the polish, always had great results with Happich simichrome on aluminum, and it leaves a protective film that helps reduce further oxidation. finish with a coat of paste wax. If you can save those wheels from the green meanies, I would recommend a full on polish at least once a year, easier off the bike with rotors and pulley removed.
Glad you mentioned taking the wheels off the bike to clean them. I was wondering about that. Have not had them off yet but I'm sure it's not to difficult. I'll look over the manual on that.
Old Nov 16, 2011 | 08:41 PM
scasey's Avatar
scasey
I will say this, don't use that White Diamond sh** on chrome it will scratch the hell out of it!!! I know the bottle says u can trust me don't. Glad it was a rental the time I experimented with it!
Old Nov 16, 2011 | 09:09 PM
noserider's Avatar
noserider
Thanks! I will say it blows the Never Dull away if your wheels are a little rough. I like the never dull but it seems to work best if your wheels are not to bad and need a little polishing.
Old Nov 16, 2011 | 09:30 PM
FDHOG's Avatar
FDHOG
Very fine brass wool. Don't use steel wool, it will scratch the aluminum.
Old Nov 16, 2011 | 09:48 PM
noserider's Avatar
noserider
I thought the idea with the steel wool was to go from a 0 ot to a 0000 ot to remove the scratching as you go?
Old Nov 16, 2011 | 10:33 PM
Bill03E's Avatar
Bill03E
I have polished lots of aluminum , and I always went with 600,800,1000 grit wet, then mothers with a cotton buffing wheel in a buffer, the type you would use in a bench grinder, surprisingly they have a pretty good selection of wheels , and compounds at Harbor Freight tools, and you could pick up a cheap buffer there too.
Old Nov 17, 2011 | 02:31 AM
klu408's Avatar
klu408
I used to polish sportbike frames on the side and after the sanding i used these items..
You dont need the sandpaper or steel wool.
go to sears and buy the polishing compound sticks.. think theres black,red,white in the kit. Get you a grinder with a sewn polishing wheel. Use the black compound first! This will eliminate all scratches and stains.then go behind it with the red jewelers rouge and for a last buff.. go with mothers billet by hand and your done... its a good bit if work but results will be amazing!! Mirror finish if done right!!
Old Nov 17, 2011 | 08:18 AM
Geoff's Avatar
Geoff
Good suggestion. I used this approach on a set of Corvette aluminum wheels. The results were great.
Old Nov 17, 2011 | 09:06 AM
noserider's Avatar
noserider
Can I use a drill with a sewn polishing wheel?
Old Nov 17, 2011 | 02:43 PM
FDHOG's Avatar
FDHOG
Why scratch it if you don't have to?
