On AM, there is always noise. Sometimes you can squelch it out and sometimes not. AM receivers, unfiltered and not very selective such as that in the HK unit, are prone to interference from lots of sources. It's not FM, so expect some static on AM. That said... Sounds like its not plugs or the stator/rotor. (based on your responses so far). If your headset works fine while listening to the radio and without the static you are hearing in CB mode, then it is not the headset.
Possibilities:
-crushed or damaged coax line leading to antenna. You would need some equipment you may not have to check this at the antenna end.
-damaged antenna. The base loading coil could be seperated or intermittent. Possibly some other issues with the antenna. Try one of your buddies antennas for to rule this out.
-Intermittent ground or intermittent center conductor to ground short in the coax or in the connector that connects coax to the antenna.
-Something may be arcing on your bike. Get your bike in a super dark place, start it, and look around in the engine compartment for anything making an arc or spark to ground.
-Pull off your spark plug caps and then push them back on.
-Make sure all grounds a solid and clean. Start at the battery terminal, and anywhere else there is a ground lug. If there is paint between the ground lug and the bare metal, scrape the paint away.
-Turn off your cell phone and see if the noise goes away on the cb
-If you have any aftermarket leds or led controllers on your bike, these can be a source of interference depending upon how their controllers are designed
-Make sure the ground to the metal plate in the bottom of the tour pak is clean and tight.
These are just a few ideas off the top of my head.
Thanks I will check out some of these items, as far as the static on AM I am going by what I hear when riding other Harleys and they don't have the problem that I do. My GPS (ZUMO 665 plays fine with nav and mp3, so I will have to check the antenna thing I checked all connections that I could find, )
Well after a lot of checking i found the problem, I did check the antennas to assure that the correct one was on the correct side and it was. It had never been off the bike but when i did take it off i found a chalky white residue around the threads, i can only assume it came from the weather (rain) I cleaned it pu not thinking that it would make a difference and applied some Dielectric grease. Well all is clear as a bell now!!! Thanks for all the suggestions I only hope that this will help some others fix their problem in the future.
That is a good check for all with the CB radio. Check your connections as stated above and put some Dielectric grease on it before it becomes a problem.
Just for clarity's sake, the CB antenna is on the side by the tourpack latches (Right hand side). My antennaes were also put on the wrong sides during setup.
One other thing to check is your intercom...do you get the static on the intercom as well or just the CB. If just the CB, my guesses would be a problem with the CB itself, or a ground issue as someone has already stated.
I have a 2011 ultra that I'm having the same problem with. It's driving me crazy on trips. My dealer more or less told me yesterday that I would have to live with it because they have tried everything they know and harley techs can't help either. Did you ever get your problem solved? Cb reception is fine if the motor is not running. Anything you can add is apprecitated.
Yes I did resolve my problem, I put a new antenna, (factory) on and used some dielectric grease on the connections and it has clear as a bell ever since.
Thanks so much. I will forward this to my dealership and some other guys that are having the same problem. Hope it works for us also. When my bike is not running, no static on receiving end, only when motor is running so I'm not sure I have the same problem but will surely check it out.
I was getting 1/4 mile at best max. reception and transmition. I also tried every adjustment possible. Read this and went outside with my dielectric grease and pulled the right antenna and it was clean. Looked at the antenna markings, guess what, it was assembled AM/FM on the right where the CB should have been. I then switched them and hope that cures my problem. Will see this weekend.
this may sound silly ,but check your antenna's they are radio and cb specific, I had removed mine an put them back on wrong and had static issues, you will find the antenna marked right down by where the threads are.
Silly maybe not, I have owned my bike 1 1/2 years. (bought used at dealer) I thought static was due to being a CB radio. Turns out both antennas were am/fm. I put cb antenna on today so I hope to have an improvement. DUH
