Extension cables for CB on an Ultra?
Old Nov 27, 2011 | 02:02 PM
mastery's Avatar
mastery
Default Extension cables for CB on an Ultra?
Long story short...I took out my CB a few years ago to put in an Arc Audio amp, since it was the only place it would fit (on top of the radio). I'd like to get the CB re-installed, and found a place inside the fairing I can mount it. Unfortunately the harness on the CB is too short to reach the stock HD radio in the off-to-the-side location I've found.
Anybody know of a extension cable I can use to connect the CB harness to the radio, and while I'm asking, a extension able for the antenna cable? I'm looking at needing a extension of a about 1 foot in length for each. I've searched, but my google-fu isn't working so well today. This is for my '08 Ultra. Thanks!
Old Nov 27, 2011 | 03:02 PM
CtCruzer's Avatar
CtCruzer
Radio shack probably have the mini cb connectors to make that up as far as harness rainy day cut and solder project
Old Nov 27, 2011 | 03:23 PM
mastery's Avatar
mastery
Not everybody enjoys soldering and cutting. Looking for a existing extension cable.
Old Nov 27, 2011 | 05:40 PM
Lowcountry Joe's Avatar
Lowcountry Joe
You are looking for something that "probably" does not exist. You will either have to make it yourself or install the CB in the intended place and move the audio amp.
Old Nov 27, 2011 | 06:14 PM
CtCruzer's Avatar
CtCruzer
Not trying to be funny
Just realistic
Old Nov 27, 2011 | 08:20 PM
vanman59's Avatar
vanman59
Default Mount it under the radio
J&M kits mount the CB under the radio. Check their website to see if you can order the mount or make one. The CB radio is pretty lite and it shouldn't take much to mount it.
Old Nov 28, 2011 | 03:41 PM
mastery's Avatar
mastery
CtCruzer: understood. Doesn't hurt to throw out the question though, never know what others have found.
vanman59: I'll check out the J&M kits. I can build a mount, place I have picked for it is just a little out of reach for the cables to connect. I could go under the radio I guess, just have to think of a different mounting fabrication.
Old Feb 20, 2012 | 03:49 PM
mastery's Avatar
mastery
Throwing this back up just in case anybody ran into the same issue over the winter and found a solution.
Old Feb 20, 2012 | 04:03 PM
Harleypingman's Avatar
Harleypingman
Couple of options: (1) send an email to Scott Ezzell (ezzell141@comcast.net) and buy his bracket; it attaches to the HK radio and you mount the amp on top, and mount the CB module below the head unit to the bracket--about $45; or, (2) use Velcro or VHB double-sided tape and attach the CB module to the bottom of the HK--I used the VHB for a year or so w/o problems until I purchased Scott's bracket.
Hope you find a solution that works for you.
Carl
Old Feb 21, 2012 | 07:21 AM
mastery's Avatar
mastery
Thanks Carl, I will look into that for a possible solution.
Gone Blue
Audio Systems
Oct 4, 2016 07:29 AM
santajim
2014-2024 Touring Models
Sep 27, 2015 10:43 AM
BungoBill
EVO
11
Jan 13, 2015 01:47 PM
flychopr
Audio Systems
Jan 20, 2014 12:44 AM
Everette
Mar 24, 2010 11:30 PM
