Head pipe
Old Nov 30, 2011 | 09:27 AM
Thresher's Avatar
Thresher
Default Head pipe
I am looking for a used headpipe to remove the cat from and use so I can keep my original pipe intact in case needed in the future. Question is, are all head pipes the same size (diameter) for 2009-2011 tourers? I have a 2011 RK standard with 96ci and wasn't sure if the larger motors use different size outlets at the cylinder? My sensor ports are down low in front of the cat. any info is greatly appreciated!
Old Nov 30, 2011 | 09:32 AM
troop's Avatar
troop
I believe they changed 02 bung size/location on the 2010 > head pipes. Check in for-sale touring section. I quite often see 2010> head pipes for sale with the cats removed. Save yourself some time/$$ ....
Old Nov 30, 2011 | 09:39 AM
modes's Avatar
modes
I believe the answer is yes to what you are asking. '09 O2's were up higher I believe, '10-later O2's were in your location. 2010 Road Glide Custom and Street Glides had 2-1 head pipes for a single right side muffler.
Adam
Old Nov 30, 2011 | 09:46 AM
Thresher's Avatar
Thresher
Thanks i'll check it out!
Old Nov 30, 2011 | 09:47 AM
Ronp42's Avatar
Ronp42
Account Retired
Your 2011 is the same as my 2010. They moved the 02 sensor's down near the collector box in front of the catalytic converter and changed the size from 18MM to 12MM. Check with some dealer's in your area, sometime they have new takeoff's. If not check with this Guy jbb1982@yahoo.com His name is James Burkhart, he does great work. I've bought two header's from him for my bike and my wife's Trike. Reasonable Too!!
fzggm4's Avatar
fzggm4
Default RE: headpipe needed
I have a headpipe (with CAT) off my 2011 Road King 96 that I took off at about 1K when I replaced the whole system I could sell you. PM me if your interested.
Old Nov 30, 2011 | 10:08 AM
blockzilla's Avatar
blockzilla
I sell them with the cat removed for $150.00 no trade in required...
Old Nov 30, 2011 | 10:21 AM
Rich67's Avatar
Rich67
I have 2 sets 1 off an 09 and 1 off 2011
Old Nov 30, 2011 | 10:26 AM
hogrider98's Avatar
hogrider98
on your 2011 you can use a 2009 and just plug the o2 ports off if you combine it with a pcv because there is no o2 sensor needed when you use the pcv
Brian
Old Nov 30, 2011 | 12:39 PM
jfarrar30's Avatar
jfarrar30
I have a decatted one I will let go cheap. Sent you a pm
Radel7
Milwaukee Eight (M8)
May 19, 2018 08:41 AM
ecupirate
Oct 15, 2012 07:04 AM
iwillfixthem4u
Apr 14, 2011 11:26 PM
KCFLHRC
Jun 17, 2010 10:50 AM
fuelmoto
Apr 20, 2010 08:29 PM
