Overheating at 55 degrees?
Old Dec 14, 2011 | 11:04 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Sounds like "Warranty Work" to me. It would be worth having it checked out.
Old Dec 14, 2011 | 11:19 PM
2black1s's Avatar
2black1s
Originally Posted by mkguitar
... OP, is your bike completely stock?
What is the idle speed ( before eitms)- low idle means less oil pressure and volume, oil is part of the cooling system...
Originally Posted by Morris9982
I have never heard of a mode 2 heat management system. Does this really exist?
Originally Posted by fabrik8r
Yep, it exists, its called EITMS, has 2 modes, don't remember the trigger temps but one mode lowers idle, the other skip fires the rear cylnder.
I am aware of EITMS (Engine Idle Temperature Management System) which I believe shuts off the fuel to the rear cylinder when the head temperature reaches the cut off point. My bike has this on it. From what I've read on here and on HD's web site, this system is primarily for rider comfort and not for the engine.
The OP mentioned a system that alternated cylinders just before shut down. I had never heard of this system or seen it mentioned on here before.
It may be real, I've just never heard of it before now.
As far as I know the EITMS has only a single function. That is to turn off the rear fuel injector when the cylinder head temp reaches a predetermined temperature (287 deg F).
As far as the purpose of the EITMS goes, rider comfort vs. engine self-preservation, the owners manual says nothing about rider comfort, but does state that the system will work to cool the engine. (Although that's a pipe dream in reality. It may slow the rate at which the temperature continues to climb, but it will not cool the engine down). The HD website does imply that the system is for rider comfort. What it's really for? Your guess is as good as mine and whichever you choose it doesn't do a very good job at either.
As for idle speed, it remains constant with or without the EITMS engaged.
Old Dec 15, 2011 | 01:02 AM
Sam2010's Avatar
Sam2010
Op descripton sounds exactly how my bike acts. I was surprised to because temps were high 40° outside hearing get a tune and lose cat is getting old. my bike got NO cooler with tune(s change of pipes cams etc.
Old Dec 15, 2011 | 06:23 AM
fabrik8r's Avatar
fabrik8r
From the TTS Mastertune tuning guide May 2010:
1. MODE 1- AFR Enrichment
2. MODE 2- Skip Fire /Rear Cylinder Shutoff
MODE 1 will be activated under the following conditions:
1. Engine temperature exceeds 142C(287F)(Sportsters 230C/446F)
2. Engine RPM is less than 1200 RPM
MODE 2 ( Big Twins Only) Activates if MODE 2 is active AND:
1. Engine temp exceeds 155C (311F)
2. Vehicle speed is less than 1-2 KPH
Note that sportster temperatures are higher due to the location of the temperature sensor and use only EITMS Mode 1 (AFR enrichment)
Note that EITMS takes over AFR control when active and user AFR tables are ignored
Thats all the info I got, I dont know if mode 2 actually has 2 parts where it alternates firing front and rear and then shifts to completely shutting down the rear. Might be something in a later model owners or service manual
Its hard to diagnose a concern like this over the web, there might not be a legitimate deficiencey but then again maybe there is. I would ask that dealer tech to show me in writing the function he is talking about.
Keep in mind the OEM temp sensor is located in the front cylinder head, I typically see rear cylinder temps as much as 30 degrees higher depnding on conditions, so when EITMS kicks in at 311F the rear can be upwards 340F, it amazes me that folks are surprised at how much heat they feel when they are basically straddling the rear cylinder and exhaust.
Old Dec 15, 2011 | 07:03 AM
skratch's Avatar
skratch
but is that a tts tuning thing only? i can't find anything in my 2010 manual in reference to 2 modes. don't have a 12 manual yet, so don't know about that one.....
Old Dec 15, 2011 | 07:20 AM
fabrik8r's Avatar
fabrik8r
I believe that is the description of the OEM EITMS functions, not peculiar to TTS.
Old Dec 15, 2011 | 10:01 AM
Sam2010's Avatar
Sam2010
EITMS On 284 off 275 mine comes on all the time when I have it activated. Those are the temps that were in the stage one down load.
Old Dec 15, 2011 | 10:14 AM
X Iron Butt's Avatar
X Iron Butt
I have true duals and when I am at a long traffic light on a hot day (85-90+) I most definatley get some relief from the heat coming of of my rear cylinder exhaust pipe that is 4 inches below my thigh when EITMS activates. If you crack the throttle you van feel it imediatly heat up through the delay to re engage the EITMS. Stop and go can't tell as much due to constant throttle ups but I know it is better than not having it.
My shovel will not run on the rear cyl alone. As I understand it was all HD's back then. Not sure if these newer Fi bikes will or not. I haven't tried it and probably won't.
Old Dec 15, 2011 | 11:04 AM
Lonewolf176's Avatar
Lonewolf176
No. The difference is that the TTS will skip fire the injectors to both cylinders instead of just the rear.
Old Dec 15, 2011 | 11:21 AM
2black1s's Avatar
2black1s
I'm thinking that is a function unique to the TTS Mastertune function also. I don't know for sure, but I've haven't been able to find any HD document that defines the EITMS as anything more than shutting down the rear fuel injector. I'm also referring to the 2011 system. It may have been different prior to that.
Back to the original question... I've said this many times in previous threads and I'll say it again here. The best solution to prevent engine overheating in congested traffic and prolonged idle conditions is an Engine Cooling Fan! They flat-out work! You'll never feel your EITMS kick in again with a properly functioning Engine Cooling Fan.
Here's a link with some testing I did to substantiate how well the fan works... https://www.hdforums.com/forum/tourin...test-data.html
And here's a link to a promising system that a another forum member is developing... https://www.hdforums.com/forum/tourin...tem-again.html
