rear lighting
Old Dec 18, 2011 | 06:17 PM
FlatBlackGlide's Avatar
FlatBlackGlide
Default rear lighting
what r u guys doing to add more light to ur streetglides/tourings??
Old Dec 18, 2011 | 06:23 PM
speedwaysteve's Avatar
speedwaysteve
I went to leds..custom dyamics..kurys.filler lite that goes over the turn signal bar also got kurys saddle bag fillerstrips and hds spoiler lites
Old Dec 19, 2011 | 06:33 PM
Egras2k's Avatar
Egras2k
First step was a BrightAssTaillight. Cannot do without it.
Old Dec 19, 2011 | 06:42 PM
dbell66253's Avatar
dbell66253
Custom Dynanmics LED's and Plasma Rod, Kury light in the middle, thinking about also adding the saddle bag spoiler with LED, but they don't seem too bright.
Old Dec 19, 2011 | 06:49 PM
Glockcubed's Avatar
Glockcubed
BrightAssLight and HD LED running/brake/turn signal module.
Old Dec 19, 2011 | 06:55 PM
jjnoble's Avatar
jjnoble
Put a couple of these on the back, they will not go unnoticed. They are every bit as bright as the ball tail light if not brighter.
http://www.brookingindustries.com/products.php?view=prod&id=94
Old Dec 19, 2011 | 07:11 PM
1SG_CFP's Avatar
1SG_CFP
All of my rear lights are run stop turn. First I put in a run stop turn kit. Then I modified the wiring in the tour pak so the lights are left/right instead of tail/side. Next I made a splitter that plugs in after the run stop turn module. (HD now makes a kit for this). Now both my tour pak rear and side lights are also run stop turn.
I replaced the tour pak lights with bright leds. I left the tail light and turn signal lights as incandescent. That way the load stays close to factory and I didn't have to put in an led load module.
I also have a detachable tour pak kit. I used a flat four trailer connector so that it's rugged and detaches/attaches quickly
aviscomi's Avatar
aviscomi
+1 on the Custom Dyamics...I have them on both my bikes
Old Dec 19, 2011 | 10:01 PM
tek-noid's Avatar
tek-noid
BAL-3, FLHX fascia, run-brake kit, and LED turn signals
Old Dec 19, 2011 | 10:39 PM
ChristoHD's Avatar
ChristoHD
Thumbs up
+1 Custom Dynamics LED's all around, and the run/brake/turn harness kit.
See demo
