Compression release valve
Old Dec 19, 2011 | 06:27 PM
1fathog's Avatar
1fathog
2010 96" does not have ACR releases. Only the 103"
Old Dec 19, 2011 | 07:27 PM
KingCripps's Avatar
KingCripps
I have the hot start problem with a stage II 103 kit as well, 255 cams. Compression releases were never mentioned when the dealer did the work. Harley says they are not needed, BS.
If I can do the work myself, $150 for drilling, $140 for ACRs and a $40 harness, I don't know what the head gaskets sell for. So I am looking at about $330. I can get the heads CNC machined for $525, considering whether or not to do that while they are off. I'm concerned about fuel usage and whether performance will be degraded because I don't want to do cams again this winter
Old Dec 20, 2011 | 02:00 AM
grbrown's Avatar
grbrown
Wink
Originally Posted by Skeeter229
Why do you think it already has a release valve? I'm not saying you are wrong just wondering why.
Not easy to answer, but one reason I can think of is to enable one starter motor to fit and start all stock engines. If the factory was to fit ever larger starters they will get bigger and more expensive, so it may be a case of balancing costs against each other.
On my 1990 bike I now have an S&S 107" which came with automatic releases. I have been running with the stock 1.2kW starter, but that has given up the ghost this summer, so I now have a 2.0kW one!
Old Dec 20, 2011 | 08:44 AM
FBFletch's Avatar
FBFletch
We've had this discussion on the forum before. Most Harley dealerships don't know crap about building a performance engine. For the most part, they're simply pulling parts off the shelf and throwing them together with little practical knowledge of how they'll actually perform together. And, while that's not always the case, it happens more often than not.
Having said that, there's plenty of real life examples out there that points to the fact with a Stage 2 kit for the 103s and the 255 cams, compression releases are needed. For a dealership to say that they aren't is either completely ignorant or completely irresponsible.
My opinion on MCRs (for about $50) as opposed to ACRs (for around $200) is that it depends on the consequences of forgetting to press the compression releases. A friend of mine used to be a service manager for a HD dealership. On two seperate occasions, the same customer brought his bike (11.0:1 CR) into the dealership because he had trashed the starter by forgetting ONE TIME to depress the compression releases. To me, that's an example where ACRs are justified. If there is little potential to damage the starter by forgetting to depress the compression releases on occasion, I'm all for MCRs.
I'm somewhat new to having CRs on my own bike. I have MCRs and thought it would be difficult to remember to depress them. However, I have yet to forget them even one time (knock on wood). Admittedly, it's easier to remember on a carbureted bike where you set the choke before a start anyway. However, it's now simply part of my pre-start routine.
Personally, given that you have a Stage 2 kit and 255 cams, if you're going to have the head off anyway, it makes sense IMHO to go ahead and have the heads machined for the CRs.
Old Dec 20, 2011 | 08:46 AM
grbrown's Avatar
grbrown
Cool
I have ACRs on my S&S 107". Never once forgotten to use 'em, in over 3 years!
Old Dec 20, 2011 | 10:15 AM
mllgator's Avatar
mllgator
I believe, auto compression releases are standard on 2010 (and newer) touring bikes, becauseI went to a "horsepower seminar" at a local dealer and the discussion/presentation centered on (their selling) "Big Bore Kits". The kit included boring out my existing 96 to 103ci, new pistons, installation of a SE-255 cam, and re-map (a tuner was recommended, but was additional $).
When the question of compression releases was raised, the tech said that 2009 & up models come with auto compression releases.
That said, if you go to a true (the set-up above is not) high compression piston, hotter cam, etc., manual compression releases may be warranted.
Old Dec 20, 2011 | 06:11 PM
Skeeter229's Avatar
Skeeter229
6th Gear
I'm just wondering how much it's going to set me back to do just the compression valves.
Old Dec 20, 2011 | 06:18 PM
rscalzo's Avatar
rscalzo
He was mistaken.
Old Dec 20, 2011 | 07:34 PM
Skeeter229's Avatar
Skeeter229
6th Gear
Would an oil cooler help with the hot-start ups?
Old Dec 21, 2011 | 06:28 AM
KingCripps's Avatar
KingCripps
Did not help me, I had one on last Summer. I would hate to be in a warm climate with these problems. It only gets over 90 about 5 days a year here.
