Visor trim ring help
Old Dec 25, 2011 | 08:51 PM
SpiderPig's Avatar
SpiderPig
Originally Posted by steelerdude1
So, It sounds like the problems that most are running into is the bottom where it clamps together has a gap, as you can see from my pics, my gap is around the headlight. As marked in the attached photo.
Is this the normal place most are having issues with? Is there a fix, or do I have to decide if I can live with it, or return it?
I just went out to the garage and looked at mine. I have the same visor trim rings as well. And it is the same as your picture shows with the gaps around the light. I really do not give it much thought as it looks fine and doesn't really look out of place. Really didn't think about it until I read your post.
Old Dec 25, 2011 | 08:58 PM
steelerdude1's Avatar
steelerdude1
Thanks for looking at yours, At least now I know it's normal.
It bothers me, I just need to figure out if I can live with it. The amount you pay for this stuff, you would think it should be a perfect fit.
Old Dec 25, 2011 | 10:15 PM
kwoozn's Avatar
kwoozn
Another reason why I laugh at those trying to sell a bike with XXXX amount of money in chrome invested on their bike!
For the most part fit and quality sux!
That being said......I have the same gap!!
Old Dec 25, 2011 | 10:41 PM
xjayx's Avatar
xjayx
My trim ring looks just like yours, I got it to fit better by loosening the stock trim ring a little putting on the new one tightening the new one down to seat it better then removing the bolt and making the stock ring snug by tightening it between the gap in the new ring then I put the bolt back for the visor ring. Made it fit a lot better for me anyway. If you want the gap gone between the lens and ring get a truck lite LED when I installed mines it makes that gap disappear, so theres your excuse for a LED headlight get to ordering.
Jay
Old Dec 26, 2011 | 06:48 AM
billnourse's Avatar
billnourse
I just put mine on yesterday, and it is the same as yours. I did a lot of checking, and it is not going back completely flush and filling the gap because the back of the ring hits the front of the fairing.
As near as I can tell, there is not much that can be done about it. I took mine off and on several times trying for a solution. I finally decided that it looked good and I got on to installing other Christmas parts.
Bill
Old Dec 26, 2011 | 07:17 AM
131tman's Avatar
131tman
Truck-Lite LED with Visor Style Trim Ring
Old Dec 26, 2011 | 07:31 AM
e6fmf's Avatar
e6fmf
Default Trim Ring
You have to buy the SPECIAL rings sold by the dealer that are made specifically to mount the visors without the gap.
Old Dec 26, 2011 | 07:57 AM
seph10's Avatar
seph10
I couldn't get rid of the gap at the bottom,,so I got rid of the stock ring,,,put sticky back foam on the new ring,,,worked great fits nice and no gap,,,
Old Dec 26, 2011 | 10:05 AM
Tarbaby's Avatar
Tarbaby
Default Visor Trim Ring
I had the same problem with mine. It laid in the garage for over a year and I desided to try it one more time. Still could not get the gap to close, tried everything. Then I came upon an idea that worked. I had some putty tape, like you would use to seal a hole around a pipe joint. Comes in a roll. sticky, rubbery. I rolled some to that into a 1/4" roll and placed it inside the trim ring, where it would fit onto the ring that holds the headligth bulb. Removed the original trim ring, put Visor Trim ring on and tightened it up! Gap closed, gap at back edge of trim ring closed , fits great no rattles. Problem solved.
Old Dec 26, 2011 | 01:09 PM
springer 03's Avatar
springer 03
You can try out all the solutions found here and on other similar threads, or do as I did, Take the POS back. All they are really good for is collecting bugs anyway.
