Need help gettig a bike to start, not sure what to check first?
I would start with looking at the pins on the ecm connector, make sure the pins aren't bent or have corrosion on them.
b1121
b1122
b1126
u1016
The u1016 code showed up in the last 3 diag sections.
My friend had an LED system installed on the bike if that makes a difference?
b1121=left turn signal open
b1122=right turn signal open
b1126=right turn signal short to voltage
The LED system is probably causing this...is it an HD system? That should hook up no problem...other systems need a modual to balance the electrical system. If they are flashing fast, sounds like the load isn't balanced...bike should still run ok though.
u1016=loss of ECM Serial data. Other than checking the pins on the ECM connector I think your going to need a breakout box to check the rest, thats what the flow chart calls for.
VSS=Vehicle speed sensor...when mine crapped out, the bike ran like crap, stalled at lights/stops, turn signals would not cancel, speedo quit and the cruise wouldn't set.
Check the pins on the connectors...check the connectors on the induction module as well. After that I would look really hard at the IAC.(Idle Air Control)
This is not a HD Led system. It's Biketronics
The speedo works fine on this bike but I don't know about cruise and canceling turn signals??I'm assuming they work because my friend didn't mention it.
I will check the connection there anyway.
Where is the IAC control at?
You can resynch the ECM to the EFI. It should tell you how in the service manual. The IAC is located on top of the throttle body next to the throttle linkage. There are three wires leading to it. One should be purple and grey. You can try cleaning that and the inside of the throttle body. Make sure that you spray into the two little holes in the top/ inside of the throttle body. Dry it well with low pressure air, or let it air dry or you may get more codes popping up.
You asked before about the ETS measurement . Here is a chart that you can use to determine if it is good or bad.
http://www.hdtalking.com/electrical/..._question.html
The bike ran decent before he took it there but he wanted more power since it's a trike. It ran better as far as power when he got it back but it progressively got worse and worse. They messed with it for three months and I think everyone got tired of the situation so here we are.
I can hardly get the thing to start at this point.
I checked the spark plugs and they were finger tight. LOL The rear plug was so loose that exhaust was showing on the top threads and around the head.
Another thing to check is the air valve screw. 07's had a problem with them backing out...
http://www.youtube.com/watch?v=PvNLc...ature=youtu.be
Is there a way to deactivate the electronic compression releases?
This is from http://www.bikerrogue.com/Articles/T...uel_Tester.htm "Granted there are numerous parts to the fuel system, but it all starts with having the proper fuel pressure. For Harley- Davidsons that is 55-62 PSI (pounds per square inch). Too low pressure can cause loss of power, hesitation under acceleration, stalling, back firing through the intake, poor fuel economy and even not starting. "
or another thought was that maybe when the "shop" was working on the bike the injector plugs got switched.
