Rotor Polish with ABS
Old Dec 28, 2011 | 08:53 PM
gringo1450's Avatar
gringo1450
Default Rotor Polish with ABS
So as I start my winter projects one of the first was to polish my rotors.
So I pulled off the wheel and noticed there is what looks like a sensor for the ABS on the rotor.
I assume I can't sand down this sensor so...
Any one polished an ABS rotor or removed and reinstalled the sensor?
Thanks
Old Dec 28, 2011 | 09:51 PM
KCFLHRC's Avatar
KCFLHRC
Pretty sure the only sensor for the ABS is the wheel bearing, but I have been wrong before.
Old Dec 28, 2011 | 09:56 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
and thats not the sensor! just the magnets for the sensor, thats on the wire running up to the tank area there are no sensors on the rotor that I know of, not even the pickup teeth for measuring wheel rotation
Old Dec 28, 2011 | 09:57 PM
harleycharlie1992
wait a minute, are you talking about the '11 or one of the other bikes you own?
Old Dec 29, 2011 | 05:54 PM
gringo1450's Avatar
gringo1450
Yes, I am talking about my 2011 FLHX
I think it might be a magnet on the rotor still need to know if anyone has removed one
Old Dec 29, 2011 | 06:27 PM
flhxkiller's Avatar
flhxkiller
there's not a magnet for the ABS on disc, what you're looking at allows the disc to float and stay centered in caliper. The stock ones have one per disc, the full floating disc has at least 3 or 4 of those per caliper. The ABS is all in the bearing and the sensor on the axle. Polish away, but don't try to take them apart
Old Dec 29, 2011 | 06:59 PM
gringo1450's Avatar
gringo1450
Ok, Thanks Thats makes sense since there is one in each rotor and the ABS sensor looks like its only on the left side.
Still it seems to be raised above the rotor surface if I grind it down flush with the rotor it will render it useless I would think.
I just don't want to F^@@* up somthing I need
Infamous Iron
May 17, 2019 01:01 PM
booquick
Feb 8, 2019 01:56 PM
Varooom
2014-2024 Touring Models
Feb 3, 2015 03:56 PM
Jetgod
Sep 24, 2011 11:39 AM
stglide
Aug 21, 2008 06:11 PM
