Cold Start Lifter Noise
I took it to the Indy who did the work. He checked my adjustable push-rods, and they were adjusted ok.
Alan
We use the Wood's lifters with all of our engine kits, one of the most unique characteristics is the very slow bleed down rate. It is not uncommon for them to take and hour to bleed down when adjusting pushrods, and we have had a couple times we left them overnight. Fortunately they are shipped with mineral oil so during first assembly they are easy to work with. They do take a few seconds to bleed up, however I have not ran into any issues where they made noise for more than 5-10 seconds when the bike sat for an extended period.
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Thank you for answering my emails today and responding here as well. I'm thinking it may be a lazy lifter or two not pumping up right away. Here are the results from measuring my two sets of lifters and my attempt at measuring the lifter bores.
Ok, here are the OD comparisons between my stock Harley Lifters and the Comp Camp 850-1.
They both seem to be very consistent at the size they are. We are talking about 0.0003 difference between the two.
I would say the Comp Cams are as good as the B lifters in OD, if anything a ever so slight egg shape of 0.0001, which shouldn't make any difference.
Standard bore to lifter tolerance listed in the Service manual 0.0008 to 0.002, and if more than 0.003, replace lifters. They should work better in a slightly worn lifter bore.
Harley B Lifters Comp Cams Lifters
Front Exhaust Flats Round Flats Round
Top Diameter 0.8422 0.8422 0.8424 0.8425
Bottom Diameter 0.8422 0.8422 0.8424 0.8425
Front Intake
Top Diameter 0.8422 0.8422 0.8425 0.8424
Bottom Diameter 0.8422 0.8422 0.8424 0.8424
Rear Exhaust
Bottom Diameter 0.8422 0.8422 0.8425 0.8424
Rear Intake
Top Diameter 0.8421 0.8421 0.8424 0.8425
Bottom Diameter 0.8421 0.8421 0.8424 0.8425
Lifter Bores all are with in 0.8435 to .8440, I've never been too good at hole telescopic gauges, but I'm sure I'm with in a few tenths.
All four lifters were well loaded with oil on top and in the oil passage which I checked when pulling them out.
I have SE Tapered Adjustable lifters and wouldn't you know it I broke a nut tonight. Guess I will be getting some grade 2 or 8 5/16 nuts tomorrow morning on the way to work, and modify them to 3/8-24 for replacements, otherwise the Harley lifters would be in tonight.....
Last edited by Hog Yild; Jan 3, 2012 at 10:33 PM. Reason: Not Grade 8 too brittle, use 5s or 2s
