Thats a helluva dyno sheet but its not really comparing apples to apples when you're running a gear driven 117" built like a brick **** house to a 103.
You might be right, however I think if you set up the 103" right you could get some big numbers. One thing I have learned is it is ALL about flow...as in head-work and a great tune. No matter what the build a good foundation, "blueprint" is what makes a build. Before I went with the 117" I had a 95" making 101/108 which aint too shabby. And that was running a 510 Andrews....should have gone with more cam on that one but the heads made the difference. Dan Vance Racing has done both sets and I attribute his work to getting good numbers. Both builds are very ridable in all respects. :-)
Have roller rockers in now, and the cam I have now has more overlap than the T-man cam. One day I will learn to leave the damn thing alone and just ride LOL Thanks for the input.
Have to agree with you on this!!! Hard to put that wrench or "thinking cap" down tho.....
What kind of power are you making and what components? You are on the right path to look to head work as it makes all the difference. When I had Dan do my heads he asked what components I was going with and set the heads up for them. For the 117" we used 110" heads and he flowed them with the HPI 58mm T/B I am using. Cost was really reasonable and the results speak for themselves. Heads should always be your "first port of call". :-)
You are absolutely right, mike_oh. Flow and tune are critical. So is using parts that compliment each other. You can go out and buy a bunch of high priced parts and put it all together and it will be a dog and run like crap too. You've got a runner because your components are working together.
You are correct sir! Now I am going to "index" my spark plugs!! It NEVER ends!!! :-) But it is sooooo much fun!! Thanks! Beers to all of you!!
