H-D revised heated grip install
Old Jan 28, 2012 | 07:36 AM
cdailey1's Avatar
cdailey1
Stage II
How did you install them just bought a kit for my 2010 ultra classic do not understand instructions heated
grips pn 56100034
Old Jan 28, 2012 | 07:44 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Does anyone know just what has been "improved", or another way to say it...what has broken down on the previous models? My ltd came with them in 2010, and I changed them out for some "chrome and rubber" heated grips to match some other chrome stuff I was installing. Sold the originals. But have not had any issues with them. Keep them around a "2", any more and they really get quite warm. Nice to have a warm inner hand, however you still have to have good gloves to keep the forward facing side of your fingers and back of your hand warm on really cold rides.
Old Jan 28, 2012 | 01:07 PM
alame's Avatar
alame
Originally Posted by 11rkc
installed same ones a few months back. do you notice the temperature is not consistent?
only was able to garage test them....see what happens on the road test in spring
Old Jan 28, 2012 | 01:09 PM
alame's Avatar
alame
grips pn 56100034
'm not quite sure what your asking here about the install ? could you be more specific
Old Jan 28, 2012 | 01:19 PM
Badgerbob's Avatar
Badgerbob
Default Heated grips
Originally Posted by williamfrog
Will the Harley heated grips work with the Krome Werks sweepers 300515? I read there was a fit issue with the TBW bars?
Mine work on my wild 1's. The only thing I didn't like was running the wire outside of the handle bar.
But it's not that bad it's the same side as the clutch and GPS, so it worked out ok I guess.
Old Feb 24, 2012 | 03:37 PM
sailnbike's Avatar
sailnbike
Default heated Grips suffer from poor design
I would stay away from the factory grips. See other posts on this forum for my picture and comments of others. The outer part of my right side grip slides off and the internal connector comes out. Also when you try to put the sleeve back on the wires and tape all come apart and cannot be fixed.
Old Feb 6, 2013 | 04:42 PM
Laserp's Avatar
Laserp
Stage I
Does anyone know what to do with the accessory power OW wire when installing harley's heated grips on a limited that has the stock heated grips? Stock setup doesn't have this wire coming from the grips. I figured I'd just ry it without it and see. If it doesn't work I'll tough it to the hot side to see if that does it. Just don't want to create a smoke show..
Wonderbob
Feb 9, 2021 05:31 PM
LKHA
Mar 3, 2015 01:58 PM
jim0249
Oct 14, 2014 01:32 AM
jeg607
Nov 30, 2012 10:07 AM
haztaz
Jul 22, 2009 11:40 AM
