Clutch cable help... Do I need to ???
Old 01-15-2012, 02:09 PM
Buckinfitch's Avatar
Buckinfitch
Buckinfitch is offline
Received 4,081 Likes on 1,514 Posts
Default Clutch cable help... Do I need to ???
I have to go +6 on a new clutch cable, (handlebar change) do I need to pull retainng ring#4 and fool with the inner ramp & ***** to swap cable ends?
or can it be done just at the ramp coupling#3 ?
I know I have the book here but it does not state to undo the whole assembly just to swap cables.
2011 FLHRC
Old 01-15-2012, 02:27 PM
Jinks's Avatar
Jinks
Jinks is offline
Once you get the cover off you'll be able to tell if you can get the coupling far enough around to get the cable end out, or if you have to release the ball/ramp assembly. Either way it's not much trouble, & a good pair of clip pliers is something you're going to need anyway.
Old 01-15-2012, 02:33 PM
BIGVTWIN's Avatar
BIGVTWIN
BIGVTWIN is offline
I did not have to when I did mine.
Pretty easy deal really. Good luck.
Old 01-15-2012, 02:43 PM
pswomack's Avatar
pswomack
pswomack is offline
The answer to your question is no, just take a pair of needle nose pliers and grab the cable end at the ramp and twist it until it comes free from the ramp, providing you've already taken it loose at the clutch lever. Install new cable in reverse. Very simple job.
Old 01-15-2012, 03:20 PM
Buckinfitch
good stuff...never changed a cable, thanks all*
Old 01-17-2012, 06:26 AM
Buckinfitch
installed adjusted and ready to roll, was pretty easy..except for the two bottom bolts behind the exhaust,
the cut down allen wrench trick made it possible without dropping the exhaust.
ConeMagnet
09-03-2014 07:54 PM
gliderman
06-05-2014 10:39 AM
07JakeelwoodHD
07-18-2011 08:52 AM
BruceHarrisJr
EVO
12-12-2007 09:20 PM
tna1000
07-25-2007 09:26 PM
Quick Reply: Clutch cable help... Do I need to ???
