New Clutch Cable and Not Enough Slack
Old Jun 4, 2014 | 08:43 PM
gliderman's Avatar
gliderman
Default New Clutch Cable and Not Enough Slack
Just replaced my Barnett S/S clutch cable with same length Magnum Black Pearl Cable. I have the adjuster collapsed all the way and still not enough slack to seat the cable in the lever perch, only getting about an inch or so of cable length at lever. Will loosening the adjustment at the clutch jam nut inside the derby cover give me the needed slack to seat the cable properly ? Seems like I had plenty of slack with the Barnett cable so curious why the new cable isn't giving me enough slack to install ? I only need about another half inch or so for it to clear the perch. Thank you for your help...
Old Jun 4, 2014 | 09:48 PM
SCJE8's Avatar
SCJE8
Yes...the adjustment at the clutch can effect available cable length. You actually need a little more cable to get the ferrule seated in the perch. Break the jam nut free and adjust the screw in to give you additional cable length to get the cable seated...then back the adjuster screw all the way out to start your clutch adjustment procedure.
Steve
Old Jun 5, 2014 | 10:39 AM
gliderman's Avatar
gliderman
Steve
Thanks Steve, appreciate the help.
DanHappy
40
May 28, 2019 12:30 PM
roadblock1
Apr 23, 2014 11:38 PM
07JakeelwoodHD
Jul 18, 2011 08:52 AM
srigas
Dec 17, 2009 08:57 AM
BruceHarrisJr
EVO
Dec 12, 2007 09:20 PM
