xied
Old Jan 15, 2012 | 04:37 PM
speedwaysteve's Avatar
speedwaysteve
Default xied
I have a 2010 sg with 20k...stock head pipe with gutted cat and se muffler stock a/c.was lookin into xied to fatten up my fuel mixture. Are they the way to go.ive pulled the plugs they arent to bad..look a lil on the lean side
Old Jan 15, 2012 | 04:45 PM
reesestewww's Avatar
reesestewww
I would suggest the ViED. You can follow this recent thread too.
Old Jan 15, 2012 | 04:48 PM
speedwaysteve
Tks i just read it put me in the right direction
Old Jan 15, 2012 | 04:49 PM
TUCCI's Avatar
TUCCI
I put the VIED (variable unit) on pretty much the same setup you have and got the results your looking for.
Old Jan 15, 2012 | 04:52 PM
reesestewww
Tucci,
Do you have any input on the thread I posted about tuning the ViED's?
Old Jan 15, 2012 | 05:26 PM
mkguitar's Avatar
mkguitar
I have the xieds and they have been an easy inexpensive solution.
2.) the novice cannot "read" plugs. Current fuel additive packages and mixtures do not leave much of an indication on the plugs.
Engine controls keep the motor operating within a narrow range.
Plug reading died in 1986, and was only a very, very coarse indication of fault ( oil fouling) or mixture-- Even if a plug showed a "rich" or "Lean" mixture- it took further testing to determine at which rpm range the motor was rich or lean. Possibly both, but under different conditions such as idling rich but lean at 4000 rpm
If you want to know what the mixture is doing you can attach a voltmeter to the o2 sensors and note the voltage under varying conditions- although the ECM will be correcting faster than you can blink.
Mike
Old Jan 15, 2012 | 05:31 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
What makes you think a little fattening is needed? Where in the map does it need the extra fuel? How much extra fuel does it need?
No disrespect intended but if you can't answer these very basic questions, then head in another direction as you're most likely going to waste both your time and money.
Good luck!
Old Jan 15, 2012 | 05:32 PM
speedwaysteve
Tks mike with the xieds what mods are you running or are you using them on a stock bike
Old Jan 15, 2012 | 05:53 PM
speedwaysteve
I know the factory tune is set on the lean side.the xieds and vieds arent very expesive.would be nice to run a lil cooler
Old Jan 15, 2012 | 06:08 PM
mkguitar's Avatar
mkguitar
I have an 09 FLHTC.
96" ness air cleaner, stock no cat headers, hi flow supertrapps.
In completely stock form the motor would ping on 6% grades between 2800~3200 rpm- the xieds solved that.
Once that was solved I went to hi flow air cleaner and the supertrapps ( which I use on a number of bikes).
Many thousands of miles of good operation, MPG at 43 MPG ( was 44 MPG before Xieds)
Mike
