unless of course, the service writer and the mech have no clue what they are talking about since.....
No clue? Go figure. Any first year tech should know the weight of a fork oil they're working with, well, you would think anyway. I don't think you'd like the ride with that heavy oil up front.
yeah, and you'd think that any harley tech would know how to re-install a dipstick after an oil change and yet i found my wife's dipstick cross threaded and sticking up about an inch...
the really amazing part of this is that hd does not sell a 30wt fork oil, so they were selling another brand vs their own.
What brand oil was it and what were the specs on the bottle?
click on the link above i posted in an earlier post.The charts show many brands of fork oil. check the various 10wt oils,,,,,,,,,none of them have the same vicosities.............every brand has their own system of determining weight ,There is no standard!
the extra heavy is the race. i haven't used it, but from what i hear, it is pretty much stiff as concrete. maybe next time, make a mix of heavy and race before you go all the way.
i've been using the se heavy and it works great in my streetglide. it removed the dive when coming to a stop using the front brakes, and improved the ride a lot. the 30 wt would be very stiff and i recommend against it. the se heavy is the best compromise for handling and cushiness in my opinion.
Where did they get it? The Se Fork oil is 7.5 and SE heavy is 10wt. I would not waste the labor and dont assemble it with that oil IMO you will be changing it bak to a lighter oil.
I like a firm ride and usually swap out springs and oil early in the ownership of my bike and on all 4 of my HDs Ive used the SE Fork oil (7.5) and in 3 Ive changed to Progressive springs
SE is 20wt. 30 is a firmer ride But you guys are being a little dramatic it takes a lot of slop out of the front end
