Tour-pak Light (inside)
Old Jan 20, 2012 | 05:43 PM
Pelonz's Avatar
Pelonz
Default Tour-pak Light (inside)
My light is melted and needs replaced. I'm looking for an alternative to the MoCo unit if somethings out there.
Old Jan 20, 2012 | 06:01 PM
05 Ultra's Avatar
05 Ultra
You must have the old incandescent light. They were replaced because of all the dead batteries they caused...The new ones are LED. Not the greatest either. But wont run the battery out. Could try one of those peel-n-stick lights. Don't think I've ever seen an aftermarket kit.
Old Jan 20, 2012 | 06:33 PM
psychocircus's Avatar
psychocircus
autozone...white led strip light...works great and super low profile.
Old Jan 20, 2012 | 06:34 PM
JB's Avatar
JB
Picked up one of these at a gas station Sylvania DOT-it Silver Self-Adhesive Bright White Silver LED Light works just fine. Or Amazon also has them
http://www.amazon.com/Sylvania-Silve.../dp/B000CNB6VW
Old Jan 20, 2012 | 07:15 PM
cdemarse's Avatar
cdemarse
I just use the cheap "tap light" usually under $10 and have a self adhesive back.
Old Jan 20, 2012 | 07:34 PM
Pelonz's Avatar
Pelonz
"You must have the old incandescent light. They were replaced because of all the dead batteries they caused...The new ones are LED. Not the greatest either."
Yea, incandescent.....good to know the overpriced LED unit isn't that great.
Trying to figure out how to tap into the 194 bulb socket to run a LED strip and utilize the mercury switch.
Old Jan 20, 2012 | 08:08 PM
Clint55's Avatar
Clint55
Thats what I use.
Old Jan 20, 2012 | 08:28 PM
K Melancon's Avatar
K Melancon
Clint55
I think I will do just that. But I think I will put some industrial velcro on back that way if I should need a light to do some work, I could just pull it off, use it, then put it back when finished.
Old Jan 20, 2012 | 08:54 PM
Lancemchn's Avatar
Lancemchn
Originally Posted by K Melancon
Clint55
That's what I did. One in each saddlebag too. When I'm camping I can pull all 3 off and have plenty of light for the tent or around the campsite.
Old Jan 20, 2012 | 09:18 PM
Whiskersvtwin's Avatar
Whiskersvtwin
Same here.. cheap LED tap light & I also keep a small LED flashlight in the tourpak.
