Interesting way to remove spark plugs
Old Jan 21, 2012 | 11:47 AM
djhrln's Avatar
djhrln
Default Interesting way to remove spark plugs
http://www.youtube.com/watch?v=_oUsF...ayer_embedded#!
Old Jan 21, 2012 | 12:08 PM
Flintshooter54's Avatar
Flintshooter54
That is sure different than I used to do my old Chevy and dirt bike. LOL Times are changing.
Old Jan 21, 2012 | 12:35 PM
shortride's Avatar
shortride
The build up of carbon on the threads may have something to do with how far into the cylinder the threads are extended.
Old Jan 21, 2012 | 12:37 PM
cdestuck's Avatar
cdestuck
Foed really had a heck of a deal with carbon on their plugs until the redesigned their head.
Old Jan 21, 2012 | 12:40 PM
TUCCI's Avatar
TUCCI
Interesting....with 100k mi plugs they have today, it almost makes sense.
Old Jan 21, 2012 | 12:53 PM
Punjabi Rider's Avatar
Punjabi Rider
Makes perfect sense most of the vehicles with Iridium plugs don't need change for 100K miles and that could be even more then 10 years on some vehicles depending on the use.
Old Jan 21, 2012 | 02:20 PM
Copyless's Avatar
Copyless
What, You think that there is carbon buildup on my iridium plugs that have 247,000 miles on them right now. Maybe it's time I change them and find out, I was going for 250,000 before I changed the plugs, but I guess I could do it a few miles sooner.
Old Jan 21, 2012 | 04:56 PM
JayDRod's Avatar
JayDRod
Never heard of loosening the plugs then turning the engine over. Not sure I really follow the benefit of that. The piece on "getting a feel for 5 pounds and then using that as a reference to apply your own torque feel" -- now that was ridiculous. I torque everything. Won't go into it here but I have some funny stories from my Navy career as a Mechanic when I came to a facility that did not even own a torque wrench. They are IMPORTANT -- don't do your own work without one.
I do use a piece of hose to get the plug started... I do use anti-seize too.. but stuff that is specific to spark-plugs which is conductive. You don't want to use regular anti-seize... maybe you will never have an issue but some general anti-seize preps are insulating and I am thinking they could reduce the plug's electrode attractiveness as a ground to the spark (reduce spark, intermittent spark... etc. maybe a possible source for problems that you can remove from the equation just by selecting the right product.
One other very good tip I have that may make my diatribes worth reading... the spark plug well on the VRSC picks up debris, sand, etc. You need to blow that out before you remove the plug or it will fall into your cylinder. Even with a tightly fitting coil boot (seal) junk gets by. Not good to get abrasive debris into the cylinder. I use 90 psi garage air and blow it through high pressure pin point hand operated air gun and really blow it around until I am sure it is clear.
(Got to have an air system... compressor, etc. or a portable air tank will do).
This is a $2 air "gun" from Harbor Freight:
Old Jan 21, 2012 | 05:14 PM
jfarrar30's Avatar
jfarrar30
This guy is a genius! I wish I would have seen this post before I bought the special tools to torque my rockers down. who knew I could have done a few quick curls with a few gallons of gas and applied that feeling to my wrench. Oh boy
Old Jan 21, 2012 | 05:22 PM
FlamedFXR's Avatar
FlamedFXR
I have 2 Fords and between them had 3 spark plugs blow out. Not cheap either.
