air shock pump
Old Jan 28, 2012 | 07:45 AM
dswansbiker's Avatar
dswansbiker
After using the Wal Mart pump you will have a good excuse for a shock upgrade!
Here is one for 23 dollars
http://www.amazon.com/Avenir-Shock-G...7758443&sr=8-5
Old Jan 28, 2012 | 07:49 AM
Lowcountry Joe's Avatar
Lowcountry Joe
I am all about saving money as well, but if you have these air shocks then you need the HD tool to keep them "inflated". The bicycle pumps are for bicycle tires, and not designed for the HD shocks. You can and will damage the air lines and/or the shocks..eventually, if you use the wrong pump with wrong volume of air per stroke.
Old Jan 28, 2012 | 08:21 AM
X Iron Butt's Avatar
X Iron Butt
I have freinds that use their air compressor and others that use bicycle pumps. They have done this for years without damage. Most of them don't adjust as mutch as I do but have not damaged anything in 5 yrs. If you have a leak fix it by trimming the hose ends past the crimp (or replace the cheap line if too short) and re inserting in fitting. For a few more bucks I got the HD pump because I could not see the gauge calibration in most adds for others or tell how easy you could let pressure off. LSHD1 has HD for $39.95 plus shipping. If you combine with other orders shipping works out to sales tax in most states.
Old Jan 28, 2012 | 08:29 AM
BigTM's Avatar
BigTM
Originally Posted by StreetGlider57
I bought a bicycle pump for mountian bikes. The pump is for the front shocks. There is a meter on the pump so I don't over fill my tires. It worked fine and did not take up too much space. Since the purchase I changed my shocks to progressive, not because I ruined the old ones, but because the old ones had a slow leak and I go tired of pumping them up. When riding two up they tended to bottom out. This no longer happens with the progress shocks.
A slow leak is ruined. I can't say if your bicycle pump caused this. I wouldn't take the chance though.
The hd pump can also be disconected without losing any preasure.
T
Old Feb 1, 2012 | 03:12 PM
BlockHead96's Avatar
BlockHead96
Originally Posted by dswansbiker
That's a good price. I have that one but it seems to still let air out when removing from the valve, when it's not supposed to. Any tricks or hints?
Old Feb 1, 2012 | 03:49 PM
hougz79's Avatar
hougz79
I also think the stem on the HD shocks is a little bit shorter than a standard stem, and a bicycle pump may not proper seat on the valve stem.
I agree, at $50 the HD pump is a rip-off, but it does work very slick. Especially for lowering pressure.
Old Feb 1, 2012 | 04:00 PM
LJROY's Avatar
LJROY
go with the hd pump. i have one and it works great. after all it is your ride we're talking about. whats $50 bucks
Old Feb 1, 2012 | 04:58 PM
streetglide44's Avatar
streetglide44
I bought mine here fir 30.00
Old Feb 1, 2012 | 05:36 PM
gomiller2's Avatar
gomiller2
I give mine a kwik pop with the air compressor it puts in a couple #pounds at a time set with a tire gauge to desired presser and roll on 99 king 13 years never a issue.
Old Feb 1, 2012 | 06:20 PM
dynawideglider's Avatar
dynawideglider
Originally Posted by dhincc
I agree. The HD pump is very small and introduces a VERY small amount of air with each stroke. And, it doesn't take very many strokes to raise the shock pressure quite a bit. Just buy the correct one and you don't risk damaging your expensive to replace (MUCH more than $60) shocks. JMO.
Ride safe!
This is the advice you're looking for.
