Ohlins in OZ
Old Mar 7, 2012 | 08:31 AM
grbrown's Avatar
grbrown
Wink
Originally Posted by Kiwiglide
Does anyone have experaince with fitting 13 inchers to a late model FLH.
Yes, Howard! These shocks are so good it is worth making adjustments to get them on. Use search for 'Ohlins' and you will find plenty of recent threads about fitting them, including using longer shocks on SGs.
Old Mar 7, 2012 | 09:28 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Originally Posted by ultraoz
(But Howard, I still reckon your arrow goes the wrong way in your diagram!!!)
Compression (-) means less oil goes through the needle valve and down the shaft to the two holes on the other side of the piston. This means that more oil is forces through the piston circuits and against the shim stacks giving more resistance.
On rebound the same oil flow but in a different direction and out the top needle seat. This means the more oil through the needle valve/shaft the slower the swingarm/wheel comes back up.
I hope this is clearer and what the + (-) means.
In this case with the + (-) switched around the key word is dampening. Lefty losey means that more oil is bypassing the piston and righty tighty means more oil is being forced through the piston.
Old Mar 7, 2012 | 09:37 AM
hog95023's Avatar
hog95023
Hey Howard mine.get.here today #694. I got somebody staying.home to sign.
Old Mar 7, 2012 | 09:54 AM
RockerMike's Avatar
RockerMike
My #6s are scheduled to be delivered today also. I'm here waiting!
Old Mar 7, 2012 | 10:16 AM
07fsxt's Avatar
07fsxt
Originally Posted by hog95023
They do hit on some bikes with aftermaket pipes from what I have read. I learned that you remedy the problem my indenting your pipe with a hammer, replicating the stock harley pipes as ohlin makes the shocks to harley specs. I called howard to get the scoop. I also am scheduled to receive a set of ohlin 6's that are longer than my streeglide Shocks today and from what I have read and seen in.photos there does not seem to be a fittment issue with this combination
I thought about denting my after market pipe too. Be warned! If you have after market pipes with removable baffles you will never get the baffles out if you dent the pipe. I found the best way is to put a 1/2" spacer between the rear mounting bracket and pipe. You will hardly notice the difference.
Old Mar 7, 2012 | 10:24 AM
mrblister's Avatar
mrblister
I'm really enjoying mine. Now I can steer with the throttle much better.
Old Mar 7, 2012 | 10:29 AM
hog95023's Avatar
hog95023
will do thanks. Im going to be adding a 124.motor.soon so I will be changing a pipe
Old Mar 7, 2012 | 10:33 AM
NC_John's Avatar
NC_John
I did the racetech front end on mine a couple years ago (converted my 05 to gold valve emulators on both sides and full racetech internals throughout) and run the true-track to keep things together. I've had Harolds site in my favorite places for a couple years now planning on getting some ohlins at some point. How much do I need to be budgeting for a pair of 6's? I came off sportbikes and ride this big girl pretty aggressively so I was real happy to see them available for the FL's.
Old Mar 7, 2012 | 01:00 PM
hog95023's Avatar
hog95023
Got the 6's delivered today!
Old Mar 7, 2012 | 02:22 PM
SouthernHD's Avatar
SouthernHD
I plan on making this my next mod on my street glide. Think they will fit ok with my Vance and Hines RSD duals?
