Braided Brake Lines...2011 FLTRX with ABS!
Old Jan 29, 2012 | 08:59 AM
UltraDune's Avatar
UltraDune
Default Braided Brake Lines...2011 FLTRX with ABS!
Anyone running braided lines with ABS? I have my ride torn down a bit to finish stereo and amp and was wanting to put some front lines on at least. HD has a kit but sure is pricey. Have done a search all over and can't find anything aftermarket. And I assume after lines are installed the dealer has to re-set ABS module or something like that. I have bled my brakes with no issues but different than changing lines I take it. Any info appreciated.
Old Jan 29, 2012 | 09:12 AM
pshaw09's Avatar
pshaw09
I just installed some last week. I purchased from Hill Country Custom motorcycles http://www.hillcountrycustomcycles.c...ines-C121.aspx Afterwards I had to take to the dealer to bleed them and reset the computer. I guess there is a sensor for the ABS. Dealer charged me $65.
Old Jan 29, 2012 | 09:14 AM
FFHD05's Avatar
FFHD05
drag specialties carries magnum sterling chromite 2 cables that are braded and clear coated u can get them in black too abs is a 3 piece line if you replace it yur upper runs from the mc to the abs block then the midline runs from the block to the bottom of the tripple trees and it connects into the lower that set up will run you about 200 roughly...
Old Jan 29, 2012 | 09:49 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Yep. Used HD Diamondback braided lines. Two years into it now. Still look for perform great. Dealer install at time of purchase. You should be able to reverse bleed your new lines back to the abs module and avoid going to the dealer. There was recent post on that procedure.
Old Jan 29, 2012 | 11:18 AM
UltraDune's Avatar
UltraDune
Awesome. Thanks for the responses.
Old Jan 29, 2012 | 04:51 PM
FFHD05's Avatar
FFHD05
what he said on the bleeding i just did a 12 limited for a friend. i unhooked the line at the block and put it in a small mason jar and gravity bled it worked like a champ
Old Jan 29, 2012 | 05:01 PM
tj316's Avatar
tj316
I did my FLTRX , I used HD Diamond cables , did the install and took it to the dealer to digitech it
JRK5892
Oct 29, 2013 11:36 AM
scj
Jun 2, 2013 02:21 PM
swanny2369
May 29, 2013 08:03 AM
97badfatboy
Wheels/Tires
Mar 1, 2011 09:42 PM
Springerfan
Mar 5, 2010 08:16 PM
