Headlight Bulb Number?
Old Jan 30, 2012 | 07:25 PM
MidnightFLHX11's Avatar
MidnightFLHX11
Default Headlight Bulb Number?
Hi Guys,
I tried searching but didn't find a definite answer. I have a 2011 FLHX and am looking to upgrade the headlight to a brighter/whiter bulb. Any idea what bulb it takes? Is it a common bulb that I can find at an auto store?
Don't want to upgrade to an LED headlight, just want a better quality bulb.
Thanks!
Also, if you have any recommendations please let me know!
Old Jan 30, 2012 | 07:33 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
its a h4 ,look at rally lights.com,they have an e code headlight housing for around 30$ its a huge improvement over stock,and they carry a huge selection of bulbs,be warned most high perf bulbs will not last long on a harley,u can also look at upping the wattage stock is 55\65 a few have used 80/100, i went with a 55\ 100 and mostly run low beam but upped the wattage on my passing lamps.
Old Jan 30, 2012 | 07:40 PM
Iceman24's Avatar
Iceman24
germanautoparts.com
Search for H480100OS (H4 80/100 Osram bulb) - bright as the sun...
Old Jan 30, 2012 | 07:43 PM
DBAGR's Avatar
DBAGR
Be careful as to how high you go on the wattage. The stock wiring will not tolerate high watt draw for long periods of time.
Old Jan 30, 2012 | 07:47 PM
DPete's Avatar
DPete
Piaa "extreme white plus" anti vibe 60/55w brighter and whiter
Old Jan 31, 2012 | 03:52 AM
leopard's Avatar
leopard
Stage I
You can go to ebay or DX , try to search it on google
Old Jan 31, 2012 | 06:58 AM
Peculierboy's Avatar
Peculierboy
You can upgrade the bulb, but it won't make as much difference as upgrading the lens like bigdumbnoitall00 mentioned. The newer lenses have a small reflector that messes up the light pattern. Get a new lens, http://www.rallylights.com/detail.aspx?ID=350 for $38 AND a bulb, you won't believe the difference. One of the better upgrades I have done....
Whiskyjock
Jul 27, 2019 06:41 AM
trappermarc
Apr 16, 2012 11:31 AM
WideBoy04
Apr 18, 2010 12:20 PM
HaggisMan14
Aug 31, 2006 06:48 PM
Beefcake
Jul 22, 2005 04:49 PM
