handle bars
Old Feb 2, 2012 | 10:44 AM
drmudd's Avatar
drmudd
Default handle bars
I
have a 2012 road glide and looking for new bars ,any ideas I like the 8in monkey bars but not sure they will be comfortable
Old Feb 2, 2012 | 11:11 AM
Matt0987's Avatar
Matt0987
I suggest you find a dealer with the handelbar test bike. That would be a place to start.
Carry a tape measure. If you see a set you like on a parked bike measure them. Then try them out on the test bike.
Find some photos of some bikes with what you like, take the photos to the test bike and show them to the dealer.
You might post some photos here of the look you are considering for others to make suggestions about, too.
Your riding style could make a difference. Do you just scoot around town? Or, do you take day long trips?
Old Feb 2, 2012 | 11:15 AM
tj316's Avatar
tj316
I ran 10" monkey bars , I loved the look , were nice around town but I wanted more pullback , they have 6" of pullback and I wanted 12" of pullback , Wild1 & Carlini had more pullback and would work I ended up having Bill at BR Custom Cycles build me a pair
Old Feb 2, 2012 | 11:57 AM
kc347's Avatar
kc347
Lots of luck on this decision. Handlebars are about as personal a mod as you will find. Matts suggestion hits the nail on the head. Do you want 1" or 1-1/4" bars. Do you want taller, wider, more pull-back. Comfort or function? Taller & pullback are comfort - wider more control. Decide what YOU want then research and find want fits your needs. On 1-1/4" bars the transition to 1" controls some mfg. taper some mfg. break totally(ie WildOnes) makes a difference adding accessaries that mount on the bars.
Enjoy your search hope you find the one that fills the bill. Ride safe.
Old Feb 2, 2012 | 12:17 PM
drmudd's Avatar
drmudd
I don't like the tall ape hangers, but like the way the shorter ones look, comfort is a must I do go on long rides
Old Feb 2, 2012 | 12:26 PM
Buckinfitch's Avatar
Buckinfitch
keep in mind that you may need to go +4 or 6 inches on your clutch cable and brake line depending on what size you go with, with 8" mini-apes you may get by with your stock clutch/brake, also consider internally wiring the control wires for a much cleaner look, especially with 1¼" dia. bars., also make sure your new bars are notched for TBW
I just installed Santee 11" mini-apes and 'almost' could get by using my stock clutch cable and brake line but did not want to jeopardize safety with tight lines.
https://www.hdforums.com/forum/touri...g-apechit.html
Old Feb 2, 2012 | 01:58 PM
CurtisO's Avatar
CurtisO
You should surf over to www.roadglide.org they have a lot of handlebar info available.
Chicagowin
2018+ Softail Models
Apr 13, 2019 11:12 AM
Big Dave
Jul 23, 2018 10:56 AM
djohn
Jul 14, 2015 08:07 AM
jlilnc14
Apr 30, 2012 02:26 PM
harvema
Oct 27, 2011 11:31 PM
