FLHT Handlebar Install Help
Old Feb 4, 2012 | 04:37 PM
Freeway's Avatar
Freeway
Originally Posted by steelerdude1
I didn't have TBW wires to deal with but I did have to run my heat demon wires through the bars, WOW what a trying experience. I'm not real sure what all is involved with the wires you need to pull through, but maybe this trick I found can help you. I got a string and used a shop vac to suck it through the bars, taped my wires to the string and pulled them right trough. I wish I knew about this trick, it would have save me a lot of time messing around with mechanics wire.
Good luck.
I think I'm pretty lucky with the bars I'm installing -- they're Roland Sands Convoy bars, which have an opening at each corner, so I used a needle-nose pliers to help push/pull everything through when it got hung up. My string broke halfway through and I would have been dead without those access points for the pliers.
Old Feb 5, 2012 | 03:17 AM
Freeway's Avatar
Freeway
A day and a half later and I'm finally finished -- for now. I buttoned everything back and up and started it but didn't ride because I'm tired. It's throwing error codes galore.
Check engine is on, cruise control is flashing, it wouldn't start until I put it in neutral even with the clutch in. Here's the codes:
P0132
P0501
P0572
P1512
P2122
P2127
P2138
It's always something...
Old Feb 5, 2012 | 04:56 AM
alame's Avatar
alame
not sure why the codes on your install, I had mine all apart to put new bars and heated grips on and everything worked fine at the end of the day, maybe check all your connections for bent pins is all I can suggest
Attached Thumbnails FLHT Handlebar Install Help-handle-bar-change-008.jpg   FLHT Handlebar Install Help-handle-bar-change-007.jpg
Old Feb 5, 2012 | 01:10 PM
Freeway's Avatar
Freeway
The neighbors are still loving me. I get up this morning, gear up, climb on and start her up, drop into first, roll on the throttle -- and there's nothing. No throttle response. At all.
So... Roll it back into the garage and think about wtf to do next.
I obviously screwed up with twist grip sensor along the way, even though I babied it more than my high school girlfriend when I was trying to get her to give it up for the first time. It's throwing codes and the cruise control light keeps flashing.
It's times like this that I wonder why I don't just pay a shop to f*ck things up for me.
Old Feb 7, 2012 | 01:22 AM
Freeway's Avatar
Freeway
Problem solved: the green connector came unplugged while I was running the wiring. Plugged it back together and cleared the codes and it's all good to go now.
JPMathers
Feb 19, 2014 10:40 PM
AThousandHurricanes
Nov 28, 2010 02:15 PM
CT-Bagger
Nov 13, 2010 07:22 PM
Boom
22
Sep 6, 2010 07:52 AM
Irish Metal
May 21, 2009 12:36 AM
