Carb Enricher
Old 02-06-2012, 06:22 PM
straightleg's Avatar
straightleg
straightleg is offline
Default Carb Enricher
Guy at work has a 99 electric glide standard I believe. Carb bike
He says he pulls out the choke and buy the end of his driveway it goes off.
He says his bike does it automatically
Does the enricher go in all by itself when warm??
I almost got all the parts for the mm efi to carb switch.
Straightleg
Old 02-06-2012, 06:46 PM
rizzo's Avatar
rizzo
rizzo is offline
Received 4,621 Likes on 2,094 Posts
Mine does -CV carb, S&S carb did not. On the CV it depends on the amount of tension you put on the retaining nut. There is not a self close mechanism like a car.
Old 02-06-2012, 06:47 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
It's the motor vacuum that pulls it in, as mentioned above, a knurled plastic nit just inboard of the pull **** sets the tension- finger tight, no tools
mike
Old 02-07-2012, 06:18 AM
Cage Dodger's Avatar
Cage Dodger
Cage Dodger is offline
I used to have a '98 carbed Sporty.
I learned the hard way how to adjust the enrichener tension.
First, loosen the metal 17mm nut on the outboard side.
Next, finger tighten the knurled plastic **** inboard of the mounting bracket just enough so that the **** stays out.
Then tighten the metal nut enough to hold the enrichener to the bracket.
Be careful not to over tighten.
Don't ask me how I know.
Cage
zimm
EVO
10-19-2013 07:34 AM
GPHDXLC
03-09-2009 06:00 PM
gaillarry
Carburetor Related
02-26-2009 07:04 AM
t059736
04-10-2008 08:45 AM
FatBoyinNJ
Exhaust System Topics
09-07-2006 07:26 PM
Quick Reply: Carb Enricher
