Help with PPG Paint Code
Old Feb 8, 2012 | 06:39 AM
Rickr01's Avatar
Rickr01
Default Help with PPG Paint Code
Hey folks, I need to find the PPG paint code for a 2010 Street Glide "Brilliant Silver Pearl?" It seems that the "Brilliant silver" is not the same as Brilliant Silver Pearl. Sprayed a sample and verified this is the case. Also the formulation is different between 2009 and 2010 and possibly even for 2011. Leave it to Harley to mix it up so you can't figure it out??
So, I'm looking for the PPG code for 2010 Brilliant Silver Pearl. I'm sure that their must be a few of you out there that have access to the PPG info?
Any help would be greatly appreciated
Old Feb 8, 2012 | 09:41 AM
Rickr01's Avatar
Rickr01
Bump, Anybody working with PPG?
Old Feb 8, 2012 | 04:42 PM
Rickr01's Avatar
Rickr01
Old Feb 8, 2012 | 04:45 PM
lionsm13's Avatar
lionsm13
You'll probably have better luck going to an auto parts/speciality store and letting them match it and it will probably be more precise too. JMO.....
Old Feb 8, 2012 | 05:19 PM
Harleypingman's Avatar
Harleypingman
Have you tried the search function here on HDF? If so, what search terms did you use???
Carl
Old Feb 8, 2012 | 09:11 PM
kevin_n's Avatar
kevin_n
like stated before you could go to a auto paint and supply store and have them match it, could also try o match it with a ford color seeing that harley and ford use the same paint or try this website http://www.cyclecolor.com/id24.htm not sure if that will help but worth a try.
Old Feb 8, 2012 | 09:24 PM
machinehed's Avatar
machinehed
Good luck ., if your interested in only touchups , go to any paint store with rattle cans .
Found my 1990 police white match at Canadian Tires home paint section.!
Otherwise ., you are at the mercy of the auto. paint shops and they will charge you $$$$!
Old Feb 8, 2012 | 09:42 PM
1CdnHD's Avatar
1CdnHD
Road King Classic, FLHRC
024 Vivid Black (Carryover)
032 Cool Blue Pearl (New for 2011)
073 Brilliant Silver Pearl (Carryover)
091 TwoTone Dark Candy Root Beer & Light Candy Root Beer (New for 2011)
183 Custom Psychedelic Purple & Vivid Black {Avail Aug - Dec 2010} (New for 2011)
184 Custom Apple Green & Vivid Black {Jan – May 2011} (New for 2011)
http://www.harley-davidsonforums.com...-codes-hd.html
Old Feb 8, 2012 | 10:02 PM
rlaf75's Avatar
rlaf75
Will these help?http://www.roadglide.org/showthread....ht=paint+codes
Old Feb 8, 2012 | 10:12 PM
timbo141's Avatar
timbo141
The only BRILLIANT SILVER for 2010 that I see is 922941 - BRILLIANT SILVER DENIM
