ARC Audio
Old Feb 13, 2012 | 12:35 PM
wrenchguy24's Avatar
wrenchguy24
Originally Posted by JoeTag
How do we get in touch with Wayne?
Just give him a call!!!
405-343-5050
Old Feb 13, 2012 | 01:12 PM
JoeTag's Avatar
JoeTag
405-343-5050
Thanks Wrench
bald1der's Avatar
bald1der
Ok after I talked to Wayne and got all the adjustments made OMFG
This system rocks !!! Its hard to even turn it over half way on volume its so loud!!
when I first turned it on I wasnt impressed at all, then I found out the adjustments were turned all the way down!!!!
So I made 2 videos 1st is my buddies 2012 bone stock Ultra
Now I have to say these videos does ot give it any justice at all
but in person it is night and day difference
So both videos are the same CD and the radio at 6 bars on volumn
WEll hell I cant get the videos to load !!! May be to big !!
Ill try again tommorow
Did you buy your system from Wayne??
So what were your adjustments.. Just curious. Reading the instructions from ARC it was talking about taking off the top, but I didn't unscrew the lid, I just used gain adjustments.
Old Feb 13, 2012 | 02:14 PM
sublime_ac's Avatar
sublime_ac
You can adjust the BX setting by taking off the lid, the idea is that it gives you a little bump in the lower mid-bass frequencies, which are audible... This gives the 'illusion' of better bass response from smaller speakers. They have the Q (frequency center / bandwidth) of this set as such that it works well with components / coaxials and I find it does work a little better than the bass setting in the head unit.
Old Feb 13, 2012 | 03:05 PM
wrenchguy24
Mine you do not have to take off the lid !!!
New design?? not sure
but all adjustments are made on top with small screwdriver
Old Feb 13, 2012 | 03:43 PM
sublime_ac's Avatar
sublime_ac
Yes, there is an update to the KS125.2, it is the KS125.1BX.. Which has the bass eq module that you adjust by taking the lid off.
Old Feb 13, 2012 | 07:47 PM
wrenchguy24
Mine has a bx2 switch on top and a bass boost button on top that you adjust with a small screw driver
Old Feb 13, 2012 | 08:31 PM
sublime_ac's Avatar
sublime_ac
Care to post the gain / bx / bass boost settings you used?
Old Feb 13, 2012 | 09:05 PM
wrenchguy24
I have the gains at about 50% the crossover just under 110 and the bass boost about 12
Old Feb 13, 2012 | 09:51 PM
2011_Glide's Avatar
2011_Glide
wrenchguy,
Did you get them from the ARC website?
What is the best price that is out there on these speakers and amp? If not able to post due to restrictions, PM me.
