SE Compensator
Old Feb 13, 2012 | 07:49 PM
Wreckman's Avatar
Wreckman
Default SE Compensator
I am planning an 11,000 mile ride in July. I am trying to cover all the bases on bike prep. I have a 2009 Ultra. With all the posts on the SE compensator I am wondering if I need to do this to mine. I have never really noticed anything clunky from the primary. Can it leave me high and dry or just make noise?
Old Feb 13, 2012 | 07:57 PM
TUCCI's Avatar
TUCCI
The way I understood all the threads on the compensators you get plenty of warning before it finally lets loose, the noise is distinctive.
Old Feb 13, 2012 | 08:18 PM
davessworks's Avatar
davessworks
Probably get away with out it but frankly you may enjoy the ride better with it. How many miles on your bike right now?
jmoore9's Avatar
jmoore9
Tucci's right on!
Old Feb 13, 2012 | 08:48 PM
Wreckman's Avatar
Wreckman
Bike has 15K on the clock. I am going to do new tires and wheel bearings.
Old Feb 13, 2012 | 08:50 PM
SteveO's Avatar
SteveO
It doesn't just let loose, just gets a loud clunk that gets louder over time when starting or shifting into 1st gear. May slip from time to time when you start the bike giving the impression of a bad starter or bad battery.
Changed mine out recently, major difference with easier starting and smoother shifting.
Good luck !
Old Feb 13, 2012 | 10:29 PM
rlaf75's Avatar
rlaf75
I changed my comp a few months back and all i can say is WOW!. What i difference it made. Its like a new bike. It wont just fail and leave you stranded. It starts out as a loud bang upon start up and will eventually turn into a grinding when the starter is engaging or trying to engage. A bad comp will eventually take out the starter clutch if let go for too long.
Old Feb 13, 2012 | 10:34 PM
soft 02's Avatar
soft 02
If it aint broke dont fix it. I think there are more 96" without the comp issue than with. I would wait for some symptoms before id crack open the primary.
Old Feb 13, 2012 | 10:47 PM
12limited's Avatar
12limited
Don't mean to hyjack the thread...but...
Wheel bearings already? This is my first HD bike...is there a known problem that the wheel bearings need changing at 15-20K? I got almost 10 on my 12 Limited...
Oh yeah...since am I am asking dumb questions already...what exactly does the compensator do? I know it is in the primary... I do not think my other bikes had a compensator...or maybe it was called something else...
Old Feb 13, 2012 | 10:56 PM
soft 02's Avatar
soft 02
Its basicly a spring loaded shock absorber between you engine and tranny. Removing the harsh shock loads of a 45deg single crank pin design of HD v twin.
