120R or big bore????
Old Feb 19, 2012 | 10:28 PM
mike_oh's Avatar
mike_oh
Originally Posted by jeff.georgalas
I haven't seen any burnouts yet, but he's gotten the front end up in my driveway a few times.
Really think these cranks are going to need to be welded to withstand all the fun you are going to have!!! Time will tell as usual.
Old Feb 20, 2012 | 06:29 AM
grbrown's Avatar
grbrown
There are several 120R threads on here, just use that in the 'search'. Keep us up to date when you get yours!
Old Feb 20, 2012 | 10:03 AM
dgdamore's Avatar
dgdamore
Originally Posted by aviscomi
I intitially was going started with the basic Stage 1 and TW-555 cams. I then felt that was enough power for me (92hp/107 torque). So I looked into some Big Bore kits, different cams & 2/1 exhaust. Most prices were coming in around $3,000ish. After giving it a bit more thought I realized that I could get the 120R for $4,700, hell that's only $1,700 more. Of course I still need the Throttle body ($350ish), Injectors ($120) and exhaust ($650). But now I have a true performance engine. Though I may swap out the cams.
Just noticed that you mentioned exhaust. I have V&H true dual headers. Will they work, or is there a header needed that is specific to the 120R?
Old Feb 20, 2012 | 10:22 AM
aviscomi's Avatar
aviscomi
They will work, but to truly reap all the benifits from this engine a 2/1 pipe (i.e. BorZilla or Dragula) would be ideal.
Old Feb 22, 2012 | 06:12 PM
dgdamore's Avatar
dgdamore
Yep, I realize that. I'm going to leave a little power on the table for now.
Old Feb 22, 2012 | 06:27 PM
NorCalFBLO's Avatar
NorCalFBLO
does anyone know the difference in cost between the crate 120 or building from bottom up??
Old Feb 22, 2012 | 06:50 PM
aviscomi's Avatar
aviscomi
About 1k, I believe the kit inlcudes the Throttle Body. I decided on the crate for the simple fact of still having a complete motor to keep or sell.
Old Feb 26, 2012 | 07:23 PM
ultra_classic's Avatar
ultra_classic
Originally Posted by mike_oh
2003 Ultra Classic 117" Making 131/138. SE 110 heads by Dan Vance Racing, SE roller rockers, forged rocker supports, Rev Perf 4.125 cylinders, Wiseco forged pistons, 10.5:1, 4 3/8 forged crank trued and welded, Timken bearing, Feuling camplate, pump and lifters, SE tapered pushrods, HPI 58mm T/B flowed by Dan Vance Racing, HPI 5.3 gpm injectors, Barnett Scorpion clutch, ThunderMax Auto Tune, T-Man 625 cams, S&S Gear Drive, V&H Pro Pipe. Built and tuned by Barry Hamilton, Kiwi Pro Cycles.
what was the budget on this build Mike? I have a 05 Ultra with 120,000 + kms or in US speak 65,000+, its runs strong but when the time comes, like the tread says 120r crate or SS crate or rebuild and go big[ger].
04glideTC
Engine Mechanical Topics
May 1, 2018 09:18 AM
DAVETHEBUILDER
Sep 16, 2010 07:39 AM
IronAss
Apr 18, 2010 12:22 AM
jtscuba02
Exhaust System Topics
19
Feb 11, 2008 08:58 AM
UltraKla$$ic
Nov 16, 2007 05:20 PM
