Finally Found The Problem
Old Feb 20, 2012 | 04:43 PM
birdmandave's Avatar
birdmandave
Smile Finally Found The Problem
Wrote thread Where To Start a few weeks ago about intermittent power lose. After much distress, this past weekend tore the ignition and fairing apart. After several hours of what the **** found a wire leading from the fairing back to the frame had a kink in it. After a splice, liquid electrical tape, and regular electrical tape, problem solved. Weekend finding a problem on your scoot, PRICELESS.
Old Feb 20, 2012 | 04:48 PM
TSD's Avatar
TSD
Congrats!!!! It's always more satisfying when you can find the problem yourself!!
Old Feb 20, 2012 | 05:05 PM
BBStacker's Avatar
BBStacker
Good job. Now you can file that under experience and maybe a starting point if something similar happens in the future.
Old Feb 20, 2012 | 05:27 PM
mkguitar's Avatar
mkguitar
Originally Posted by birdmandave
... After a splice.....
hope you didn't solder it.
soldered joints fail on bikes due to vibration
mie
Old Feb 20, 2012 | 05:31 PM
tj316's Avatar
tj316
mie
I've soldered everything I've ever done on all my bikes and use marine grade heat shrink and never had an issue , crimps can corrode over time
Old Feb 20, 2012 | 05:39 PM
mkguitar's Avatar
mkguitar
copper strands tend to break right where the solder tin ends, often concealed by the insulation
have a look, you'll be surprised, I know i was many years ago- after wiring my first bike ( luckily it was all adapting the lighting up front- it still ran)
it explains why automotive connections are crimped
I'm pretty good at wire management- I work with electronics
it'll work tomorrow, and the day after, and the day after that- but get enough miles on it and....
mike
Old Feb 20, 2012 | 05:48 PM
Mike's Avatar
Mike
Likewise.
Old Feb 20, 2012 | 11:24 PM
X Iron Butt's Avatar
X Iron Butt
If properly crimped soldered heat shrunk and supported I have never had a failure in a soldered joint. The better Marine engine manufacturers use tinned wire and solder every crimp. So do I where possible. The last crimp should be around the insulation to support the wire at the soldered joint.
Old Feb 21, 2012 | 04:05 AM
jjnoble's Avatar
jjnoble
Solder, crimp, I don't know which is best. I've seen just about everything fail. I use both and don't worry about either one. The OP mentioned he used electrical tape, that never works for very long, okay to use it as an added bonus if it makes you feel good, but not as the main insulation. If something shorts out, you still have to check everything no matter what was used.
90fltcu
EVO
17
Aug 14, 2014 04:41 AM
Keithhu
May 2, 2013 01:45 PM
eathomps
Dec 10, 2011 09:56 PM
RockyNC
Apr 14, 2011 11:54 AM
millercm
May 4, 2007 11:05 AM
