FLHTC Pulls Left
Old Feb 23, 2012 | 01:16 PM
Whiskersvtwin's Avatar
Whiskersvtwin
Default FLHTC Pulls Left
Hi folks.. I thought I posted this yesterday but cannot find it.. that was after the Glenfiddich.
Does anyone have any experience with their bike pulling one way or the other? When I let my bars go, she'll drift left and I want her to go straight.
This started after I had my front bearings replaced last year at the dealer.
I am also getting a little front end wobble in the sweeps at about 30mph.
Thoughts?
Thanks,
Whiskers
Old Feb 23, 2012 | 01:58 PM
Wardenbf's Avatar
Wardenbf
Thoughts?
Thanks,
Whiskers
I can make my bike go left, right, or straight by moving the clutch cable up or down in the clamp on the fork leg. Try it and see what happens. It's free.
Old Feb 23, 2012 | 02:33 PM
mkguitar's Avatar
mkguitar
got any extra weight in the left saddlebag?
wobble- 90% it's incorrect tire pressure
6% it's a worn tire
4% it's gremlins
Mike
Old Feb 23, 2012 | 02:37 PM
Bleachey's Avatar
Bleachey
Lean right. Just kidding.
+1 on the saddle bag causing drifting. I had my left bag loaded up (leathers, rain suits, allen wrench and cheap wrench set) because I usually put my computer bag for work in the right bag. One day I didn't bring my computer home from work and took the long way home and noticed it wanting to drift a little, not too much but I noticed. Balanced it out and problem went away.
No idea on the wobble.
Old Feb 23, 2012 | 03:08 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
I hate to be Mister Obvious..... but.............
Old Feb 23, 2012 | 04:59 PM
JoeN's Avatar
JoeN
had a bad wobble at exactly at 30, no faster and no slower. front tire had 20 psi
Old Feb 23, 2012 | 05:12 PM
mrfikser's Avatar
mrfikser
have you adjusted the drive belt??maybe the rear wheel is out of alignment..
Old Feb 23, 2012 | 05:35 PM
Scottybob's Avatar
Scottybob
My 11 SG doesn't track straight and you wouldn't know it unless you go no hands. A little lean to the right and it's all good. Id go with uneven weight distribution in the bags.
Old Feb 24, 2012 | 10:56 AM
Whiskersvtwin
Thanks for the replies. And yes, I did check the tire pressure, and that checks out and I'll be emptying the bags before heading to the shop and see how that goes. I'm not too worried about the drift, but the damn wobble is bugging me. I can only see the bars wobble at 30 with no hands and figure, wtf, who rides with no hands, but.. in the tight turns at 30 I can really feel the front end shake, and that's with the hands on.
These things didn't start happening until I had my front bearings replaced last year, at 11k wtf, and as I pulled from the shop I almost lost it due to the serious wobble. I went directly back and waited another hour while they tightened up the front just beyond spec and she seemed fine.
I had them check again a few months back and they didn't find it, but I'm going back tomorrow before my extended warr expires, because they'd likely find it after that.
Thanks all.
Old Feb 24, 2012 | 02:41 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
the previous bad bearings may have caused some weird tread wear and with the new bearings now your feeling it?
