I have the matching BBP lowers, and have the CVO speaker pods already painted to match. The paint will be fine. I won't finish this little project until spring, as I'm about to pull the trigger on bars,color matched fairing, chrome controls,etc. I plan to install the Biketronics 4180 amp, and Hertz speakers. IMHO-aesthetically, and sound wise, this is hard to beat. The painted pods look so much better than most of the alternatives offered by the aftermarket. Maybe I'm just an **** retentive SOB...( I am ). I say do it right (professionally) or not at all... My .02...
How much did it cost to get the speaker pods painted? I think I am going to have to try this.
I modified my Rockford Fosgate speaker grills to fit the lower fairings. I purchased the stock HD grills but didn't like the tweeter clearance issue and how they fit the speaker.
I removed the 1/2" raised section of the grill. Then I slowly removed 1/8" of the diameter of the circle. They look great and fit perfect.
Tools I used 2" air grinder with flap disc and 3m 2" wheels.
You will not see the ground edge as it sits below the surface of the HD speaker pod.
Iam running 4 Fosgate t165 and PBR 300x4 scotts Awesome bracket and HK head sounds great
This beats the J&M huge disappointment that I had last year. Sold that junk for half the money.
Nice write up indeed. I did the same thing this weekend. I did not have time to take pics as I had a million things going on. I just want to add a couple of helpful things I ran into. Carl mentioned one above but I did something different.
1. The directions tell you to drill the outer fairings per the small illustration. They then tell you to run the wires through the opeining in the speaker box. I drilled the hole in the outer fairing first, then put the speaker box in place, then marked the box by sticking a nail in the outer fairing hole to mark the location on the outside of the speaker box. Then I drilled the outside of the speaker box so the holes line up. It makes it a lot easier to run the speaker wires. Keeps them in a straight line if you want to move the wire after you put everything back together.
2. I used a 3/8 grommet on the hole in the outer fairing. If you want to use the speaker wire that comes with the Harley kit (as in Harleypings pics by his speaker boxes) like I did then use a little gun oil or lube by the grommet to help pull the wire. The wire will slide very easy and you won't get pissed by the wire not pulling by being too tight or having just the wires pull with the outside sheath not moving.
Also if you take the entire lower fairing off (makes it way easier to work on taking the vents off, etc.) make sure you have the rubber washers that go on the lower fairing, lower bolt. You probably will not be able to re-use it. The part number is 7415A if memory serves me right. I didn't have the washers when I took everything apart and had to run to Harley on Sunday to get the washers after the fact.
They may not be biggies but will save you a little bit of time a aggrevation.
Toeser, props on a successful project; glad you are happy with it; and, you're welcome.
Meist21, thanks for the suggested install improvements--they make sense, though I had no difficulty w/o them.
It's been a good while since my installation. Except for the painted inner fairing w/spun aluminum gauges, this project gives the most pleasure--enjoy it every time I ride--the project was relatively inexpensive (in HD terms), look cool, and is an effective audio upgrade.
