ipod interface install problem
Old Feb 27, 2012 | 11:47 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Originally Posted by fish eye
Any details on the Iron Cross kit? Does it still allow full control through the handlebar controls, and does it also show the information on the screen?
Yes, and yes
And compare the price http://www.ironcrossaudio.com/ipod-h...dsonradio.html
Old Feb 27, 2012 | 01:27 PM
Harleypingman's Avatar
Harleypingman
Originally Posted by cliffjump
I read the block wrong the block is numbered from one side 1 thru 12 then from the same side 13 thru 23 then 24 thru 35 . So i had the pin in the correct hole. but I still only have sound out of the left speaker. the rest of it works well the song title and artist are displayed on the radio display and it is easy to move for song to song.I may have damaged the wire that connects the ipod to the unit. I connected the wire to the back of the control box to check the lenght and when i disconected i did not realise there is a slip collar on the wire to release the conection . I may have pulled 1 on the connection pins loose in the block.but i canot find any visible damage.
Originally Posted by shooter5074
Push all of the wires into the connector while the connector is seated to make sure you have good contact. When you plugged the 35 pin connector back in, you may have pushed a pin back out if it didn't lock.
As shooter mentioned, it's very common that a socket did not lock when inserted even though it may seem as though it's been fully inserted. Check the connector by looking at its insertion side. You should see the sockets contacting the inside edge of the red plastic of the sockets you inserted--if the socket isn't against the inner surface, it won't make contact with the pin out of teh HK radio.
Another way to check if the socket locked is to gently tug on the wire. The socket may fully insert, but if it's not correctly inserted, the locking tang won't engage and the wire needs to be rotated to reorient the socket to lock.
Hope you find your problem.
Carl
cfave
Audio Systems
Jun 22, 2017 01:23 PM
Munkee
Audio Systems
43
Aug 16, 2014 12:22 AM
uwiik
Audio Systems
11
Nov 11, 2013 02:40 AM
webbug
Dec 30, 2010 10:43 AM
jgcable
May 16, 2010 06:19 PM
