Radio Static
Old Mar 1, 2012 | 02:09 PM
bcane98's Avatar
bcane98
Default Radio Static
So my bike sat for a couple months while the weather was poo poo. Ran into a small problem though... I turned the radio on and nothing but static. Checked all my connections (except under the hood) and found that I pinched both CB and Radio in the rear fender support covers... UGH! Once I corrected that situation, tucked them into the support cover, I can get a couple radio stations when scanning, but not even close to the ones I usually listen to.
Any suggestions... both cables have what looks like a fold where they were pinched. I will check under the hood just to make sure though
Current setup:
09 Ultra Classic
TP Quick Disconnect
HD shorty antenna's x 2
-- 1 CB, and 1 AM/FM
Thanks
Rick
PS... I tried to post this in the Audio section of the Tech forum, but not much response there
Old Mar 1, 2012 | 04:23 PM
mfortkamp's Avatar
mfortkamp
im gonna say that when you pinched them you either broke the wire inside or on of the outside shielding wires im now touching the inner wire and is giving you your bad reception.
May have to replace the wires. Another possibility is go to and audio store and have them cut out and splice the spot where it got pinched. Thats where I would start.
Adventurer
Audio Systems
Feb 9, 2017 06:47 PM
hoakken
Audio Systems
Oct 9, 2016 01:50 PM
rdbjac
Audio Systems
Apr 16, 2013 12:23 PM
bcane98
Audio Systems
Feb 29, 2012 01:09 PM
lupner1
Audio Systems
Oct 16, 2011 09:33 AM
