I changed on 2002 RKC to Brembo front brakes. Installation went ok, I bleeded the system and initially I had a real good pressure feeling in the lever. After moving the bike back and forth I am loosing the brake pressure. I get the pressure back after pulling the lever couple times. But when I move the bike again the issue is back.
What could be the problem? Perhaps the Piston of the master cylinder?
Warped rotor sounds like a very good start point based on what you have described
When you have pumped the brakes a few times the pads are very close, if not in contact with the disk. Only a small movement of the lever is required to bring the brakes up to pressure
If the disk is warped, as you wheel the bike back and forth it forces the brake pistons back in to the caliper. You will then need a few pumps to get the pistons back out and in contact with the disk
Stupid question, but are you sure no air in the line? Right amount of fluid? Did you cycle the caliper a few times before you installed them just to make sure there was movement ?
Bleeding is, agreed, the most obvious issue to be eliminated. The inference of the OP is that, without moving the bike, the brakes are fine. Worth double checking though
I use a Mity-Vac to bleed my brakes. It takes about 10-15 minutes to completely bleed both calipers on the front. You can pick one of the plastic bodied ones (sometimes branded as "OEM") at most auto parts stores for about 30-35 bucks. Much easier than trying to bleed manually.
Also, when you get brake pressure, hold the lever in and check all the fittings to make sure you're not leaking anywhere.
Before you start worrying about a warped rotor, check to make sure you don't have air still trapped in the lines. I think that's your culprit.
