Hello, just wondering if the turn/brake/run module will turn the lower led in the rear fender into a brake light on a 2012 street glide? I read a few threads and on 08's and earlier it would not do it. Thanks
I have custom dynamics run turn brake module and it diffently does have the brake and function.Check out their web site they have videos of their stuff in operation.
It is my understanding that the turn/brake/run module will not turn the lower LED into brake light. You will need a different lower LED, which Harley sells. The one that comes with the bike is not connected to the brake light circuit. I know that because I had to replace mine...
Just today I replaced the stock Tri-Bar with the HD Run/Brake version (67774-10) on my 2012 SG. While I didn't pay much attention before, when the brakes are applied the Tri-Bar lights go on a click before the upper brake lights. Odd. The installation was very quick, very simple, very easy. Probably 15 minutes once you have parts/tools (T-20 Torx) ready. I belive there are some threads here about modifying your existing Tri-Bar to be a run/brake, take a look if that interests you.
Next week my Custom Dynamics order should arrive with full LED's for front and back along with the load equlizer and a "Magic Strobe". The Magic Strobe is like a "Back-Off" module that will provide 10 various flash and strobe options covering both stock lights and LED's.
67774-10 is for '10-later FLHX models and costs $30 more
I can’t understand why 68358-07A is compatible with ’09s, the year starting the wider fender and what would be different on an ’10 that would require a different part.
LED's are faster to turn ON when compared to regular light bulbs. That's why you see the difference.
