Is dyno always required?
Problem is my wife now enjoys going on rides with me, and although she only weighs about 135 lbs, the performance drops noticeably when we ride two up. I ran the issue by my local Indy and he suggested installing a better cam to pick up a little more power and low end torque. He broke the whole set up down to me and I was all on board until I discovered that it cost about $400.00 to dyno tune the setup afterwards!
He quoted me $1900 for the entire install, which means that the tuner (TTS Master tune) and required dyno eat up about $800 alone! I know you get what you pay for but that seems a little steep, doesnt anyone make a tuner that doesnt require a dyno to dial it in?
Fuelmoto will give you free maps for life, and you can do tuning runs which record your riding and the software will suggest tweaks to your tune, or you can send the data to Fuelmoto and they will tweak the map for you.
This approach saves you the $400 for the tune.
Jamie's maps come from bikes he's tuned with your same parts, so the tune will be very very close.
You won't know what your missing if you don't go...
Yes it's expensive.... but it's WORTH double the money.
You either KNOW, or you DON'T.
Traveled 969.7 miles round trip from Canton Georgia to Minneola Florida.
Now that I KNOW, I'd have traveled twice as far, and payed double the money.
Are you a fan of the "smoke and mirrors b/s hype?" Forum sponsors pay advertising fees to push their products. Extremely knowledgeable folks have been banned for pointing out flaws in those products. Greed for the almighty dollar has cost us all a vast knowledge base of information.
I haven't drank any koolaid, but I've seen the facts, and they are verified.
To answer your question, YES... you need a dyno tune (TTS is absolute best) by a COMPETENT TUNER.
Your bike will run with the others... but will not out perform the TTS mastertunes abilities.
If you go another route, you may be completely satisfied. I went the "best" route, and have absolutely no regrets. Money well spent. I got the value per dollars spent.
Your money, your bike, your call...
A dyno tune is only as good as the tuner, and how much time($$$) you/he is willing to spend.
Having AT ability gives you the freedom to make changes without having to worry
