install question on HD LED headlight
Old Mar 13, 2012 | 10:37 PM
onedae's Avatar
onedae
Default install question on HD LED headlight
I'm installing the 7" headlight on my Streetglide and the 3 small screws that attach the headlight retainer ring to the mounting ring will not go in. It appears that the holes in the mounting ring are not threaded. Nothing in the instructions to indicate how to deal with this. Anyone who installed this headlight have any thoughts?
Old Mar 13, 2012 | 10:52 PM
JJHOG's Avatar
JJHOG
Unfortunately MOCO opted to be cheap and you have to thread those holes. The screws that you took out of you stock Headlight Assembly should be self-starting threaded screws. You can use them or if you have a tap set you can tap the holes or finally look at the screws that came with the kit and if they are self tapping you can use them. In any case you have to be carefull not to strip the thread. For what MOCO charged for the LED Kit you would have thought they could have provided a finished product.
emdx3
Feb 26, 2019 05:39 PM
amkaos
May 8, 2015 04:51 PM
Sierra141
May 23, 2013 05:59 PM
casique
Aug 17, 2012 01:58 PM
Gray_Drifter
Oct 1, 2011 07:07 PM
