Chrome hand controls?
Old Mar 25, 2012 | 08:11 PM
DBLX's Avatar
DBLX
Question Chrome hand controls?
I put on new chrome brake and clutch levers. I did not bleed the brake system prior.everything went well. However when I apply the front brakes the lever is very hard and the front brakes don't work now. I have an 09 street glide with abs. My guess is I need to bleed the front? Since I have abs, do I have to take it to the dealer to bleed the brakes?
Tia,
Mj
Old Mar 25, 2012 | 08:15 PM
Zuul's Avatar
Zuul
Default Work with Annette
You shouldn't do anything yourself without the Service Manual for your bike. If you don't want to fork over the big bux for the hard copy you can download the PDF version for $10 and save a tree in the process.
Then you can read the recommended step by step on bleeding brakes with ABS and decide if you want to take it on or bring it in.
dawg's Avatar
dawg
Did you just change the levers or did you put on chrome master cylinder too? Just levers shouldn't require a bleed. Sounds like you did something else wrong. It is not required to have a dealer "bleed" ABS brakes, it is simply that a digital technician is required to check the system for air and that is only when the module cables have been affected.
Old Mar 25, 2012 | 08:18 PM
silverbullitt's Avatar
silverbullitt
I am with dawg on this one. Something isn't right. I just put on chrome M/C, switch housings, levers on an ABS bike, no problems.
Old Mar 25, 2012 | 09:03 PM
DBLX's Avatar
DBLX
I have the sm. It says to use the digital tech to verify air is removed. All I replaced was the levers. So Im surprised as well. The lever is rock hard with about an inch travel. Could it be the reservoir piston?
Old Mar 25, 2012 | 09:47 PM
RaceFace's Avatar
RaceFace
Is the lever you put on absolutely identical to the one you pulled off? Maybe its catching somewhere in the purch.
Old Mar 25, 2012 | 10:03 PM
caaraa's Avatar
caaraa
2009 Road King Classic SERT WO 509 16" Apes VH Twin Slash Rounds Mustang 4 pc super touring seats - various chrome.
Old Mar 25, 2012 | 10:25 PM
mmcbeat's Avatar
mmcbeat
Might try putting your old lever back on and see it your brake works as it should.
DBLX
Dec 26, 2023 08:21 AM
Cornel
Jul 10, 2015 09:59 AM
PFWiz
Jan 26, 2014 07:35 AM
silverbullitt
Feb 24, 2012 10:05 PM
Navy Mustang
Mar 13, 2010 03:39 PM
