Should I change tapets
Old Mar 31, 2012 | 01:15 AM
Born2cure's Avatar
Born2cure
Default Should I change tapets
I have about 30k miles on my 08. Going to change cams should I change tapets at this time. I assume so but as an armature wrentch learning as I go like confirm. Also if not necessary would like to save cash. If so which tapets are recommended, or should I just go SE Harley.
Thanks
Old Mar 31, 2012 | 01:16 AM
gsxrboy96's Avatar
gsxrboy96
I would, with that said, I use vthunder lifters in a majority of my bikes... Chad
Old Mar 31, 2012 | 11:08 AM
gilbos440rt's Avatar
gilbos440rt
If yours are good then you'd be OK, not to say springing for new ones would not be the best course of action though. If I remember right they are a roller type so you don't have the wear pattern on them like a older car type flat tappet would.
Old Mar 31, 2012 | 11:28 AM
2black1s's Avatar
2black1s
I put cams (and gear drive) in my Duece with 51,000 miles and did not change the lifters. The bike now has 80,000 miles and all is well.
If I were doing the same job for someone else and I had to warranty the work I would replace the lifters, unless the customer understood and accepted the potential risk. But being my own bike it was worth the risk to save the bucks as I would only have to answer to myself if there was an issue.
If you have no issues with your lifters now and you are doing the work yourself, save the money. Roller lifters can last a long, long time. You can always replace the lifters at another time if you have a problem.
Old Mar 31, 2012 | 11:47 AM
07standard's Avatar
07standard
i just put cams in my 07 with 30k. took the lifters apart and everything looked good so i stuck them back in..
Old Mar 31, 2012 | 02:21 PM
Lowcountry Joe's Avatar
Lowcountry Joe
I believe with that mileage, I would probably change them out. That way you can buy a better quality aftermarket lifter, do it while you are in the cam chest, and you can cross any future lifter issues off your list.
Old Mar 31, 2012 | 04:04 PM
mr396's Avatar
mr396
I have an 2008 as well with about the same miles on it. i am looking at replacing the cams too and will be replacing the lifters with Feuling lifters, also probably replacing the tensioner pads (or I might go with gear cams). I am looking at replacing the camplate, oil pump (feeling's hi flow oil pump) , push rods, inner cam bearings, etc. I figure if I am going in there I am going to replace and upgrade it so I shouldn't have to do it again.
cajun1957a
Sep 11, 2017 10:18 PM
martin10
Engine Mechanical Topics
Dec 10, 2015 11:46 AM
Flhrhog
Dec 1, 2014 09:00 AM
twism_23
Exhaust System Topics
11
Dec 7, 2012 01:40 PM
Luxe
11
Sep 28, 2006 07:36 PM
