Installed Chrome forks, now brake problems?
Old Mar 31, 2012 | 07:40 PM
sortasuave's Avatar
sortasuave
Unhappy Installed Chrome forks, now brake problems?
Hi all,
I finally got around to installing the chrome fork kit my wife got for me this last Christmas on my 07 Streetglide. After getting it all together, I spun the front wheel by hand while the bike was up in the air and noticed that the breaks drag a little... .especially on the right hand side.
For example, hard spin with no calipers installed, wheel goes around 2-3 times
With calipers installed, goes around 1 time.
Is that right?
Additional data points:
  • The front wheel has never been taken off this bike since it was purchased.
  • Bike has 26K on it
  • Front brake pads have been changed once, I honestly don't remember how many miles ago that was
  • I've verified that I have installed the tire with the stem to the right (as described in the shop manual) and that the arrow on on tire is going forward.
  • FWIW, the front rotors were installed on this bike from the factory backwards (right side rotor is on the left side of the while and vice versa..) I repeat that the front wheel has never been off this bike till now, so I **KNOW** it came from the factory like this when I purchased the bike brand new. I guessing this is not really a problem and that it's more important that the pads and rotor remain matched up throughout the life of the pad.
  • The right hand brake seems to be the one dragging as I can take off the caliper and the problem goes away.
  • The dragging is constant all the way around so I don't believe the rotors are warped.
If the stock brake system is a floating system, that might explain the the slight drag, but I can't seem to confirm one way or the other if the bike came stock with "floating" rotors. (Yes, I know, that HD floaters are different from 3rd party rotors...)
Thoughts?
Old Mar 31, 2012 | 11:25 PM
RaceFace's Avatar
RaceFace
Did you mix up the wheel spacers on the reinstall? I believe the short one goes on the right side and did you tighten the axle nut to HD's specs? Over tightening may make a difference here.
Old Apr 1, 2012 | 05:22 PM
sortasuave's Avatar
sortasuave
I've checked that more times than I care to count.. So I'm pretty confident that I didn't mix them up. Add to that, where I think the rub is coming from is the inside pad of the right caliper. If I put the long one in there, it would force the wheel a hair to the left and would then have more pressure on that pad.
Is anyone aware of shims for the caliper?
Any other ideas?
Old Apr 2, 2012 | 11:59 AM
sortasuave's Avatar
sortasuave
Ok, so.. Can someone confirm, did the bike come stock with floating brakes? That might explain the problem...
Old Apr 2, 2012 | 12:13 PM
madjimmax's Avatar
madjimmax
If the bike was bought brand new I don't believe that they came with full floaters. I have an 05 RK and when I installed my chrome legs I bought and installed chrome full floaters also.
RGC WILLIE
Nov 7, 2015 09:17 AM
EasTexUltra12
Jun 23, 2015 04:05 PM
iclick
Nov 21, 2011 03:11 PM
JDixon
Mar 25, 2008 05:33 AM
G Funk
Feb 15, 2008 07:23 AM
