15 amp radio memory fuse
Old Apr 1, 2012 | 10:44 PM
gman2781's Avatar
gman2781
2nd Gear
Default 15 amp radio memory fuse
I have an 06 street glide that just started blowing the 15 amp memory fuse for the radio. I was wondering if anyone has had this issue before? I have not taken the outer fairing apart yet to take a look at the wireing. I figured before I did that I would come here. Also I have not done any mods recently. Thanks
Old Apr 1, 2012 | 11:19 PM
Lowcountry Joe's Avatar
Lowcountry Joe
If you are blowing a 15 amp fuse, then you have something shorting to ground. See if there is anything else being fed from this fuse and trace some wiring. Something may have worn through over time and is now taking the circuit to a direct ground short.
Old Apr 2, 2012 | 09:17 AM
gman2781's Avatar
gman2781
2nd Gear
Ok thanks joe. I'll check to see if there is anything else fed by that fuse. Everything else seems to be working fine though. I found a couple people have having problems with the wires rubbing under the fairing on one of the brackets. So I guess I'll start there? Thanks
Old Apr 2, 2012 | 09:46 AM
BlackPearl#1's Avatar
BlackPearl#1
Default Had it
I had the same thing with mine and when i removed the outer fairing i could smell that electrical insulation burning smell that we all fear. Took a while, but finally found it like you said. It was on the left (while sitting on bike) fairing bracket. Wire was not damaged so i cut a chunk of shrink wrap and zip tied it arounf that wire. At the same time have a few minutes and do the same with others that look like they might do the same thing someday. Hope this helps
Kris
Old May 29, 2012 | 09:50 PM
Zhallart's Avatar
Zhallart
6th Gear
Hmm - two replies both say wire rubbing bracket. Maybe me too?? My memory fuse blew. Replaced it and it worked for a bit. Not sure when it re-blew. Need to watch the next one.
jmelcher
Jun 5, 2013 09:44 PM
gobblerhuntr
Mar 3, 2013 08:44 AM
Whiskersvtwin
Aug 20, 2012 11:49 AM
jpalm
Mar 22, 2011 10:37 PM
BlackPearl#1
Oct 16, 2010 11:45 AM
