2007 ultra
Old Apr 11, 2012 | 06:59 PM
epd612's Avatar
epd612
Default 2007 ultra
I have a 2007 ultra classic. I noticed today they I have a small leak coming from the clutch cable on the engine side. Is there a seal that needs to be replaced or what!? Thanks for any info you can provide me
Old Apr 11, 2012 | 07:34 PM
HD Jim's Avatar
HD Jim
I noticed the same thing before I changed out my handle bars and cables. Have you tried tightening the cable a tad? That might do you right, but its not hard to change the cable, so why not go ahead and knock it out just for the peace of mind.
Old Apr 11, 2012 | 07:39 PM
epd612's Avatar
epd612
Never really work on a motorcycle before! I may try it!! lol
Old Apr 11, 2012 | 11:52 PM
X Iron Butt's Avatar
X Iron Butt
I have the same slow leak. I will wait to fix when I need to do something else in that area. Not showing a loss on the trans dipstick so not real worried. While you are looking I have seen some posts about the steel brake line for the rear brake getting a hole worn in it. When I checked mine it seems to be good but the clutch cable goes over top of the brake tube right after the forward turn out of the trans cover. The convoluted tube on the brake line was pushed forward past the point of contact with the cable and the cover on the clutch cable is worn through at that point. I pulled the convoluted tube back between the cable and steel tube and put a cable tie on it.
Old Apr 12, 2012 | 07:04 AM
epd612's Avatar
epd612
Well I did what you said! Tighten it alittle! And I guess I tighten too much. Yep!! Broke the clutch cable! . Ohh well that's what I get I guess for not knowing anything about it. I guess that little o-ring was leaking alittle. Now I will b heading to the Harley shop to get a cable!! lol. Lucky I got the screw/stud part out of the cover! Will see what happens next! lol
Old Apr 12, 2012 | 07:49 AM
Ribitt's Avatar
Ribitt
Cool
There is a oring in there that when it is gone it will leak, if you have extended warrenty it only cost 50 bucks for new on.
Old Apr 12, 2012 | 07:57 AM
epd612's Avatar
epd612
I don't !! Will b fixing myself!!
harleyrider1990
Mar 10, 2016 08:41 PM
Chunker
Jul 13, 2011 10:12 AM
Geezer glider
Jun 27, 2011 09:57 PM
Glide'n09
Apr 7, 2010 10:02 PM
jamesheritage
Jun 4, 2008 01:22 PM
