Revolution Performance
Old Apr 19, 2012 | 09:01 AM
Lowcountry Joe's Avatar
Lowcountry Joe
It's a great system and I really do like what it did for my Ultra 103.
Can't figure out why they can't flash anything past the 2010 ECM. I have emailed Andrew with that question and I received no reply. Maybe they can't "crack" the security on those?
Anyway, the theory of the system is sound and the performance is great. More power, no decel popping, no starting problems, gas mileage stayed about the same, better sound, and all that while staying closed-loop with the wide-band 18 mm sensors up at the exhaust port where sensors belong.
I hope they can get going on the later ECMs because if they cannot, then their price point will be too high for most once you factor in having to purchase a 2010 or earlier ECM.
Old Apr 19, 2012 | 01:46 PM
DBAGR's Avatar
DBAGR
Originally Posted by 2011UltraLimited
Talked to revolution performance on Tuesday and they do not flash the 2011 ECM's at this time. So I decided to go with the screaming eagle race tuner by Harley and to have them Dino the bike as well to tune it properly.
I understand your choice to go with a different tuner, but consider taking it to JD cycles in Bethlehem, Pa. They use TTS which is similar to or better than the HD tuner, and you will get a much better tune than you will at the dealer. JD's have probably the best dino operator anywhere within a 300 mi radius of where you are. You will get a canned map from any of the dealers in your area.
Bird Man
Apr 20, 2019 01:21 PM
Cpt Morgan
Jan 18, 2015 08:16 PM
randybragg12@hotmail.com
Nov 4, 2010 08:51 AM
pazzekalle
Jul 20, 2009 03:48 PM
Hammer02
Dec 5, 2008 11:04 PM
