Radio Problem. Help!
Old Apr 20, 2012 | 07:45 AM
TVagee's Avatar
TVagee
Default Radio Problem. Help!
My radio screen flashes on and off and will display lines going vertical, which makes it hard to read. This started happening shortly after I installed led signals front and rear without a load equalizer. I was wondering if that could be the reason. Any ideas?
Old Apr 20, 2012 | 09:21 AM
hojones's Avatar
hojones
There's some info on here about the problem you are having. It probally is where the display board connects to the motherboard on the radio. Do a search, from what I remember it is a pretty simple fix.
Old Apr 20, 2012 | 10:07 AM
TVagee's Avatar
TVagee
Thanks for the reply. That make more sense than the leds doing it. Of course this started happening as soon as my warranty ran out.
Old Apr 20, 2012 | 10:50 AM
tidbit1's Avatar
tidbit1
I have LED installed and i did require an equalizer. It would be easy to see if you put the OEM bulbs back in then see if the Radio problem is corrected.
sire86
Road Trips
Mar 25, 2018 10:46 AM
bizzi
Electrical/Lighting/Alarm
Oct 22, 2016 03:58 PM
The painter
Jul 23, 2013 02:59 PM
FFLETCHER
Oct 30, 2008 06:24 PM
1flhtk4me
Sep 11, 2007 09:01 AM
