I tried everything you can do , wrapped them rewelded, re routed etc, and sold them...now I have some fatshots, with 13 rings, and an endplate...nice and deep , and quiet, and you can adjust it up and down to taste....also tried stock., for my 09, not bad, 2011 non cat, too sharp, or tinny....supertrapp, or fatshotz...you wont be sorry...
I have a set of "stock" pipes which came off a 05 E-Glide Standard. If you like quiet, let me know if you're interested. Love the Rinehart's. Wife would rather listen to those instead of tunes. Nothing like them!!
I have a brand new set of stock mufflers that came off my 1990 Ultra. They would probably fit as the BUB made Rineharts I believe are the same 1 3/4" head pipes.
I don't want them stock quiet, just a low tone rumble. I had loud pipes on all my earlier bikes and that has been "a few" over the last 40 years. Guess I'm just looking for a more relaxing ride.
Hogman,,,when I mentioned it to my wife, she said she didn't notice that they were that loud. Thats just means they rather listen to the pipes then us.
Guy's a while back one of the members had the answer and no one picked it up. Pull the baffles and take a dremel tool or what ever and cut 2 V's in the baffle on opposite sides and bend them in (like the old beer can openers) towards the front of the baffle. I did two tabs towards the front and two tabs toward the back. now these are on opposite sides and bent them in. Don't get too carried away they still need to breath. The nice thing is they quiet them down and now there is back pressure which is the knock against them as far as performance . If you have too much back pressure just stick a dowel or something in there and open it up a little. Totally adjustable --- IT WORKS
Yes sir, did it to mine and like I said don't get carried away -- I bent mine (all 4 tabs in 90 degrees) in and the bike would hardly run, so I put a dowel in and opened it up and it worked. just use a little common sense. I think it took away the rinehart wistle, quieted it down, and gave some back pressure. Easy mod.
Did you do the stage one? The module/flash and the AC? Or did you just replace your pipes? You keep mentioning back pressure. If you did it right you don't need that added back pressure and the extra back pressure is having an adverse effect on your bike. If all you did is install the Rineharts then you negatively effected the performance of your bike by installing the Rineharts to begin with.
Leave customizing exhaust to the professionals. Buy loud pipes, quiet pipes, high pitched pipes, rumbling pipes, or whatever combination you want and then leave them alone, or install different baffles. Like BCT's for example. Bending things around, drilling, and sending bolts through your baffles at angles is not going to provide the results you want. Something will always suffer.
